CJN STIG
I have a mystery sound I need you guys' help with...
On my '88 Targa, there is a "scrunching" sound that comes from the rear when I roll over a dip or a bump in the road. It is like nails on a chalkboard, and I cringe every time I hear it!!
The weird part is that the sound only happens in cold weather. If the weather is warm, then no sound! I have stood on the bumper and rocked the car up and down, and I cannot duplicate the sound that way. Therefore I figured it's not the suspension. I changed all four shocks last year. This is the first winter where I notice the sound, I've had the car for two winters now. My engine mounts were perished, so I replaced those with some WEVO Semi-solids, fully expecting the problem to be fixed. Nope. "Scrunching" sound is still there. I have no clue what the problem is now, and hope someone out there has either experienced the same problem, or I can get good suggestions to trouble-shoot. Thanks |
Spring plate and/or sway bar bushings.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
If you can hear the noise going in, or out, of angled driveways, you probably have a broken rear sway bar mount.
Keep the Shiny Side UP! Pete Z. |
Senior Member
Rear shock mounting at the top not fully secured? A loose A/C on the decklid?
Sorry not to be of more help but I know how I hate those Area 51 noises!
'78 Targa in Minerva Blue |
CJN STIG
I'll reach back there and check the rear shock top mounts. I was wondering about those.
Rear sway bar mounts are fine. Last summer I did replace the spring plate bushings with some Elephant Racing bushings. That might be it... |
