BigEquity's Avatar
HELP PLEASE! Trying to find an o-ring for a Fuel Distributor Plunger
Hi all,
I am trying to find a fuel distributor plunger o-ring for my '77 911s. I have looked on the pelican site, but couldn't find what I was looking for. I got a kit from specialTauto.com that looked like what I needed.
Unfortunately, the plunger o-ring they sent me was just slightly larger than the original, and it doesn't want to stay on. Here is a picture of the two. The new one from the kit being on the left.
I think the kit is for a later model fuel distributor that had the adjustable holding pressure, un-like mine pictured here.
Anyone know where I could get one of these? Thanks!
- Matt
Old 03-01-2013, 08:15 AM
wolds's Avatar
If you have dimensions for what you are looking for, McMaster Carr would most likely have what you need.
Lorraine 83 SC CAB RoW
2003 C4S coupe
07 BMW R1200RT
76 BMW R90S
76 BMW R60/6
Old 03-01-2013, 08:21 AM
76 911S Targa
Look in the yellow pages of your local phone book under machinery or bearings. Call the bearing supply and ask if they have O-rings. Most bearing places also have every O-ring imaginable. Take your parts to them and the helpful man behind the counter will measure what you need with a micrometer and return with the proper O-ring. It will cost less than $5.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 03-01-2013, 08:26 AM
schumicat's Avatar
I just replaced that o ring using a $20 o ring assortment you can buy at autozone etc. they had one that was a perfect match.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 03-01-2013, 08:27 AM
BigEquity's Avatar
Thanks for the quick responses everyone! I found this place here in town, from a friend. I am gonna run down there, and see if they hook me up with the o-ring. Thanks again. You guys are cool!
Old 03-01-2013, 08:32 AM
matt gineo's Avatar
Call Larry at CIS Flowtech. He has everything you need
Home - CIS Flowtech
1976 911 Targa 2.7 CIS
Sienna Metallic /Diamond Sahara # 436-9-3 - Red Interior
1963 356 SC- crashed
1962 356 C- sold
1965- 912- sold- fun but too slow
Old 03-01-2013, 12:04 PM
