wolds's Avatar
Radio Install power source
I'm getting ready to install a new radio in my car to replace the old after market radio. The previous install was questionable and I'm trying to figure out where the radio sources its 12VDC and power for memory from. I looked in my Bentley, but I don't see a reference to the radio in it. I figure I'd piggieback the memory 12VDC off the clock and I could take the source 12VDC off the light switch, but I'd just as soon wire this as the factory did. Any suggestions?
Lorraine 83 SC CAB RoW
2003 C4S coupe
07 BMW R1200RT
76 BMW R90S
76 BMW R60/6
Old 03-01-2013, 05:15 AM
schumicat's Avatar
host site has factory wiring diagrams which will tell you wire colors for power/switched power than run to radio. but like you say you can just get it from any available source.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 03-01-2013, 05:48 AM
Local Mad Scientist
Andy911sc's Avatar
There should already be wires down there. Get yourself a voltmeter and set it to the chirp mode when power is detected. Make sure you have a good ground and some gator clips, so you can do it hands free. Ground wire is obviously the brown. Speaker wires are obvious also. Just see which one has power without the key in and make sure the other has power on/off with the key to on position. No need to start the car. I might have some close up pictures on my thread
1982 Porsche 911sc
2009 Jeep Grand Cherokee Laredo X
CPA-PCA Member Since 2012
Old 03-01-2013, 05:59 AM
wolds's Avatar
Thanks for the info guys.
2003 C4S coupe
07 BMW R1200RT
76 BMW R90S
76 BMW R60/6
Old 03-01-2013, 06:03 AM
Local Mad Scientist
Andy911sc's Avatar
I have confidence in you. Just take your time and if you are unsure, post some pics. We will try and point you in the right direction. I used to do custom stereo installations back in high school as a side business. That money got me through my first year of college loan free.
1982 Porsche 911sc
Old 03-01-2013, 06:10 AM
Recreational Mechanic
Nickshu's Avatar
There should be a yellow w/ red stripe wire that is 12v+ for the radio in there somewhere. HOWEVER your wire may be red, from reading old threads there seems to be some variation here on different 911's with no real consistency, some have radio wires that are yellow/red and some have solid red.
The ground wire (brown) runs across from the MPIII ground area which runs together w/ the headlight switch harness and grounds in the frunk, just forward of the back of the fuel/oil gauge.
This may help:
Which one of these is the Factory Radio/Stereo Ground Wire?
Good luck!
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches
PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing
wolds's Avatar
Thanks, I just printed off the wiring diagram from the host. Looks like the radio gets 12VDC from the ignition switch and should be a yellow wire if I'm interpreting this right.
2003 C4S coupe
07 BMW R1200RT
76 BMW R90S
76 BMW R60/6
Old 03-01-2013, 07:03 AM
nineball's Avatar
typically constant is yellow and switched is red but you never know what you are getting into when someone else has "worked" on it before. your best bet is a multimeter and a beer
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 03-01-2013, 11:38 AM
Local Mad Scientist
Andy911sc's Avatar
best advice ever.... Multimeter and a BEER! and if you get stuck another BEER wouldn't hurt. I know I downed a few when I was working on mine.
1982 Porsche 911sc
Old 03-01-2013, 11:42 AM
wolds's Avatar
How much beer?
2003 C4S coupe
07 BMW R1200RT
76 BMW R90S
76 BMW R60/6
Old 03-01-2013, 12:20 PM
nineball's Avatar
Originally Posted by wolds View Post
How much beer?
enough
Old 03-01-2013, 12:27 PM
enough
No such thing.
Dan
'86 Carrera coupe
Old 03-01-2013, 12:40 PM
nineball's Avatar
of course there is, i just haven't reached that point yet. still trying though, especially on the weekends.
Old 03-01-2013, 12:49 PM
Nickshu's Avatar
Oh sorry, It's either solid Yellow or Yellow w/ red stripe.
Not RED as I said above....my memory failed me!
Old 03-01-2013, 12:58 PM
wolds's Avatar
10-4, I'll grab a beer and my DVM tomorrow and go look, right after I clean my windshield channel in preparation for the windshield install next week.
2003 C4S coupe
07 BMW R1200RT
76 BMW R90S
76 BMW R60/6
Old 03-01-2013, 01:37 PM
