Brake experts help I have a strange problem
Put rebuilt ATE calipers on front cannot install pads on one side of caliper the other side fit's fine l/s caliper r/s pads don't fit at all. The pads are about 1/8" too thick.
The calipers were bought rebuilt I didn't rebuild them. The car is a 77s. ![]() ![]() ![]() ![]()
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera Last edited by kodioneill; 02-28-2013 at 01:20 PM.. |
Ian on my iPhone so it's hard to get a close up view of the photos but to me it looks like the piston is not pushed all the way in
Ernie 81sc |
Local Mad Scientist
I take it those are SC calipers and from the picture looks like fronts. It almost looks like whoever you got the rebuild calipers from used the spacer in between the two halves from the rear calipers which are thinner. Plus those pads look a lot beefier than the pads that went in on my SC fronts.
1982 Porsche 911sc 2009 Jeep Grand Cherokee Laredo X CPA-PCA Member Since 2012 |
The pistons are in all the way. I think I received "s" caliper pads instead of "a" caliper pads.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
probably wrong year pads for the calipers or rotors, different series (midyear, SC, Carrera, etc) had different rotor thicknesses, if you are stuck you could sand 1/16" off each pad to make them fit...
That was it. The pads that I purchased are 13.5mm thick should be 10mm.
Local Mad Scientist
I thought they look thick. Because on my SC, I was able to get pads in with the vibration pads on the back and still have wiggle room.
Whatever you do, know that the pads are too thick and not right so please refrain from jamming them or forcing them in there. I had the same problem with an old VW bus I had and jammed them in. Know what? It would not move even when the pedal was pegged to the floor. Something is amiss so get the right pads before you try to make it work. A simple mix-up at the rebuilders or somewhere.
