kodioneill's Avatar
Brake experts help I have a strange problem
Put rebuilt ATE calipers on front cannot install pads on one side of caliper the other side fit's fine l/s caliper r/s pads don't fit at all. The pads are about 1/8" too thick.
The calipers were bought rebuilt I didn't rebuild them. The car is a 77s.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 02-28-2013, 01:17 PM
emac's Avatar
Ian on my iPhone so it's hard to get a close up view of the photos but to me it looks like the piston is not pushed all the way in
Ernie 81sc
Old 02-28-2013, 01:21 PM
Local Mad Scientist
Andy911sc's Avatar
I take it those are SC calipers and from the picture looks like fronts. It almost looks like whoever you got the rebuild calipers from used the spacer in between the two halves from the rear calipers which are thinner. Plus those pads look a lot beefier than the pads that went in on my SC fronts.
1982 Porsche 911sc
2009 Jeep Grand Cherokee Laredo X
CPA-PCA Member Since 2012
Old 02-28-2013, 01:31 PM
kodioneill's Avatar
The pistons are in all the way. I think I received "s" caliper pads instead of "a" caliper pads.
1982 chiffon 911sc
Old 02-28-2013, 01:41 PM
Cory M's Avatar
probably wrong year pads for the calipers or rotors, different series (midyear, SC, Carrera, etc) had different rotor thicknesses, if you are stuck you could sand 1/16" off each pad to make them fit...
kodioneill's Avatar
That was it. The pads that I purchased are 13.5mm thick should be 10mm.
1982 chiffon 911sc
Old 02-28-2013, 01:45 PM
Local Mad Scientist
Andy911sc's Avatar
I thought they look thick. Because on my SC, I was able to get pads in with the vibration pads on the back and still have wiggle room.
1982 Porsche 911sc
Old 02-28-2013, 04:50 PM
Whatever you do, know that the pads are too thick and not right so please refrain from jamming them or forcing them in there. I had the same problem with an old VW bus I had and jammed them in. Know what? It would not move even when the pedal was pegged to the floor. Something is amiss so get the right pads before you try to make it work. A simple mix-up at the rebuilders or somewhere.
Old 02-28-2013, 05:06 PM
kodioneill's Avatar
Thanks for the advice I would never force anything I learned a long time ago not to.
1982 chiffon 911sc
Old 03-01-2013, 01:08 PM
