cary's Avatar
Another Bentley Error ?
Putting the engine back in my car. Installing my new sport motor mounts. Went to put them in the transmission cross member and.......... Bently calls for 56lbs. on that M8 bolt and nut combo.
No Way ........It calls for 18lbs. on the body ones in the back.
Can't find the spec in my Porsche Factory manuals.
Where would I find that info. Someone that's BTDT.
TIA
Cary
77 Carrera RS w/3.2 #59
73 914S 2.0 AG
73 914 1.7 Driver ( daily driver, under complete rustoration )
74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor
Old 07-06-2002, 11:06 AM
rstoll's Avatar
Sounds like an error to me. I believe you should go with the 18 lbs.
Robert Stoll
83 911 SC
83 944
Old 07-06-2002, 11:24 AM
Early_S_Man's Avatar
Porsche Crest
It is the M12 bolts through the center of the mounts that get 59 lb-ft ... the M8 bolts to the transaxle crossmember (or body in the case of the rear mounts) still get 18 lb-ft as usual!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 07-06-2002, 12:15 PM
cary's Avatar
That's what I thought, and did. But just wanted to make sure.
Both the SC and Carrera book are the same and wrong.
Wayne my e-mail notification isn't flying.
Warren I did copy off your hardware torque chart.........but left it at work.
Cary
73 914S 2.0 AG
Old 07-06-2002, 01:03 PM
