dcarlson's Avatar
'86 carrerra O2 sensor
can someone point me to correct O2 sensor for my stock carrera - can't get at car right now..
'86 944
'86 911
07 cayman
Old 03-01-2013, 04:09 PM
dcarlson's Avatar
our host parts list does not seem to target it - will this work
Bosch W0133-1604453 Oxygen Sensor | Auto Parts Warehouse
'86 944
'86 911
07 cayman
Old 03-01-2013, 04:17 PM
schumicat's Avatar
you can just use a generic sensor $15 at pep boys and splice the wires.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 03-01-2013, 04:39 PM
Go-Kart Mozart
JAR0023's Avatar
Bosch 13913 for '86 Ford Taurus worked for me. Just splice in the wires. Crimp not solder. Can be had at just about any FLAPS for less that $30. -J
Old 03-02-2013, 09:22 AM
djcdmv's Avatar
I used the Taurus one, also...
Dave
Black 1985 911 Carrera M491
Old 03-02-2013, 01:09 PM
dcarlson's Avatar
thanks for responses/suggestions - just trying to get one that will be direct fit and not require splicing, etc. Suppose I'll have to get old on out first to match it up to something
'86 944
'86 911
07 cayman
Old 03-03-2013, 04:49 AM
Hunt3R's Avatar
Pelican does list it:
Bosch O2 Sensor for 911 (1986-89), 911 Turbo (1986-94), 911 C2/C4 (1989-94)
But it's $134.50. I spent about $100 less by going to Autozone and picking up the aforementioned Bosch 13913 for an '86 Ford Taurus and splicing it into the old connector. I used weatherproof butt connectors to connect the wiring and then wrapped the whole thing up tightly with electrical tape.
Old 03-03-2013, 06:26 AM
dcarlson's Avatar
thanks, appreciate the suggestions. Hope it has some positive affect on poor running motor I've been trying to sort..
'86 944
'86 911
07 cayman
Old 03-05-2013, 12:00 PM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
It won't, throwing parts at a problem may or may not fix the problem. The role of the O2 sensor is minimal. If you can't find a Pelican to help you out take it to a good performance Pcar shop for diagnostics.
BTW, what is the problem? Poor running covers a huge spectrum.
eric
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 03-05-2013, 03:08 PM
dcarlson's Avatar
well... found a vac hose off at back bottom of throttle body - re-connecting helped a lot but still have a missing/hesitation when acceleratlng..most still telling me I likely still have some vac leak(s) . this came on suddenly with no deterioration in motor performance over time...have done wires, cap, rotor. fuel filter, air filter, DME, new coil. will try some new plugs I guess but will be tough for mew to get at them. . Starts, runs, idles good but just when accelerating .. it is obvious that something is holding motor from taking off normally..
'86 944
'86 911
07 cayman
Old 03-06-2013, 03:13 PM
rokemester's Avatar
The Taurus 1996 sensor is a four wire. How did you make this work with the three wire a 3.2 liter uses?
OXYGEN SENSOR, HEATED, 4-WIRE -- 16.93 in. wire length; Threaded-in type; Includes male connector and easy-to-follow instructions; Quality tested to ensure efficient fuel combustion; A high quality, OE replacement oxygen sensor; Features stainless steel shell, hex nut, shield, Teflon-covered insulated wires, high-temperature rubber internal and external seals, and threaded tube coated with anti-seize compound; Helps reduce harmful emissions; Backed by 1-year, unlimited-mileage warranty.
Northeast Ohio
1987 Porsche 911 Targa
1966 VW Beetle, 6V
Old 06-26-2013, 07:16 PM
Hunt3R's Avatar
86, not 96.
Old 06-27-2013, 07:27 AM
