privatepang's Avatar
Odometer issue
Hi guys,
I just wondering which cable controls the odometer reading within the speedo? I have seen a few threads where people are testing that part of it with a drill bit. When i hook it up to the car, I can turn the dial and the reading at the base of the speedo will jump through the digits however when I plug it into the car & go for a drive, speedo works but the odometer or the reading at the base of the speedo doesn't tick over...
Last note was that I replaced an existing miles/hr speedo to km/hr and the odo worked in the previous speedo so thinking it might be the gauge?
Any advice would be appreciated.
Thx
1975 Aubergine 911S - Barney
"When that doesn't work, and it doesn't quite often, it's as though your face has been amputated." - Jeremy Clarkson
Old 03-01-2013, 04:19 PM
howard freeman's Avatar
Odometer drive gears are bad,common issue. Contact Jeff Kaplan @ odometergears.com
Howard
Howard Freeman
80 911 SC & 74 914 1.8
79 930 & 83 SC coupe,03 996 TT,02 996 C4
03 X/5 3.0. 370,186 miles now Sons daily driver
10 X5 3.0I 224,515 miles
Old 03-01-2013, 04:47 PM
jmod's Avatar
Hi,
Unfortunately odo gear failure is common. There are some good threads and a Pelican Technical article on the problem at
Pelican Technical Article: Odometer Repair - 911 (1965-89) - 930 Turbo (1975-89)
Depending on the speedo you might be able to source a the odo gear in Australia. I fixed mine by following one of the threads.
Regards
Jim M.
79 911SC
Old 03-01-2013, 11:50 PM
