clnilsen's Avatar
Question Loud engine noise/belt vibration??
I want to pick your guys' brains on something on my car (1980 911 SC)..
This started a few days ago, after coming back from dinner after a hot day. When I started the car, I got a horrible squeek from the engine compartment. It was intermitant for 30 seconds, and then stopped.
I shut it off, and checked the oil. No problem there. I did drive the car home very carefully and parked it for a few days until I had a chance to look at it. I have not been able to get the noise to happen again after playing with it today though.
However, I note that the belt to the A/C compressor seems to wobble a lot when the a/c is activated, but runs smoothly when the A/C is off. There seems to be normal tension on the belt, but I have no way to check.
I am wondering: do you think that the noise is somehow connected to the belt issue? also, if they are not connected what do you think the noise should be? Should I be worried about the belt at all?
I am thinking that it may be some issue with the A/C compressor, since i have been running the A/C a lot. BTW the A/C seems to function normally, I get cold air.
Thoughts?
Thanks!
Chuck
Chuck
1980 911 SC Targa *Sold!*
2003 Boxster
2013 Beetle Turbo cab
Old 07-06-2002, 06:27 PM
rstoll's Avatar
Could be the A/C belt. Mine shakes pretty good when running air conditioner. (York compressor). Check tension on belt. If noise repeats, turn off air to rule it out.
Robert Stoll
83 911 SC
83 944
Old 07-06-2002, 06:45 PM
I think they make a brace to prevent the compressor from vibrating to much. No sure, a mechanic here in town mentioned to me.
Richard
86 930 Turbo
"Julie"
K27-BB Intercooler, BB Muffler..
Weeeeeeeeeeeeeeeee
http://www.pbase.com/rjgilliam
Old 07-06-2002, 11:15 PM
Early_S_Man's Avatar
Porsche Crest
Chuck,
Since it probably needs adjusting ... take the A/C belt off to test for the vibration. Be sure to check your alternator/fan belt tightness, too! If you don't have s total of EXACTLY six pulley shims in the alternator pulley 'stack' ... that can cause a vibration that is/wiil be destroying your fan hub and outer pulley half!
Summertime is a bad time to ignore belt/fan/pulley issues!
You don't want to repeat the recent 20-minute engine-cooking ordeal!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 07-07-2002, 09:01 AM
