Caveman Hammer Mechanic
ClickClickBoom's Avatar
Fuel injectors!
Ok,
The price hit on the 028 150 158 was spectacular to say the least!
I decided to try to see if I could do better price wise. There is Lucas disc injectors available, but it just seems wrong to put Lucas "Prince of Darkness" electrical parts onto a Porsche. That left rummaging around here and on the Internet to try to find a solution.
I came up with several possibilities:
Bosch injectors various part numbers,
P/N.................... g/pm......cc/pm.....Ohms
028 150 158.........179.........229........2.4. Stock
028 150 364........ 196.........251........2.4
028 150 360.........186.........238........2.4
028 150 165.........182.........233........2.4. My install
My choice is slightly richer, by a very small margin. After a test drive up and down the Boulder Creek Hillclimb (Jamison Creek), I am happy with the install, which took about 1.5 hours, mostly removing stuff that was in the way and replacing it.
Best part is I got the injectors on eBay for $35.00 each and shipping was free. Only slightly more than a flush/overhaul from some of the O/H shops. The injector application is for a Jaguar 3.6 to 4.0 motor. A side note is my car idles about 100 RPMs higher with no other changes to the setup. I also have a Steve Wong chip and cat bypass tube installed(off road use only).
http://www.nojac-competition.com/web/IMG/pdf/INJECT.pdf
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 03-06-2013, 02:56 PM
db_cooper's Avatar
Don't worry about the Lucas injectors (I am the last person on earth that would attempt to defend Lucas, believe me)
The injectors are made my Siemens..they also get re-badged as GP-Soresen and Tomco.
I have a set in my 1991 VW Vanagon (different part..same disc nozzle design)..they work just fine.
Which Bosch injectors did you use?
Old 03-06-2013, 06:12 PM
Member 911 Anonymous
DRACO A5OG's Avatar
on my 3.2 I installed the metal bmw/buick injectors, simply perfect
'85 Carrera Targa
PCA/POC
Old 03-06-2013, 07:52 PM
028 150 165 for a Jaguar. The fuel flow is as close to the 028 150 158 as you can get.
Old 03-06-2013, 07:59 PM
Just because, public service!
Old 06-17-2014, 08:35 AM
gtc gtc is offline
abides.
gtc's Avatar
Just curious, did you stop using the 0280 150 157s?
I just bought a set, and was going to install them when my engine goes back together.
Graham
1984 Carrera Targa
Old 06-17-2014, 10:59 AM
The fuel flows for the 0280 150 157s are not quite right at 161gpm and 206ccpm,
Whereas the 0280 150 158(stock) 179gpm and 229ccpm.
Old 06-17-2014, 04:43 PM
Can you post a link or source for the 028 150 165 injectors? Thanks!
Old 06-17-2014, 06:30 PM
5 Bosch Fuel Injection Valves L Jetronic 0280150165 for Jaguar XJ6 | eBay
Old 06-17-2014, 10:24 PM
gtc gtc is offline
abides.
gtc's Avatar
Well $hit.
Graham
1984 Carrera Targa
Old 06-17-2014, 11:11 PM
Slippery Slope Victim
NY65912's Avatar
I installed the 0280 150 157 injectors after my fuel line/ injection upgrade project. My car has never run better. Plugs indicate nice and clean. IICR, the CO measured .5
I am very happy with the Jag injectors. Idle is smooth and clean. Much, much better than before. The price was ridiculous cheap. I paid $120 for all six, free shipping and got them in two days.
Great find, thanks Click!
MikeČ
1985 M491
Old 06-18-2014, 04:17 AM
Mike, where did you find them for $20 each?? Thanks!
Old 06-18-2014, 09:45 AM
NY65912's Avatar
Ebay.
http://www.ebay.com/itm/Jaguar-XJ6-1990-1992-Fuel-Injector-OEM-Bosch-Free-Shipping-/261127225523?pt=Motors_Car_Truck_Parts_Accessories&hash=item3ccc6540b3
MikeČ
1985 M491
Old 06-18-2014, 10:25 AM
TheSt|G's Avatar
Originally Posted by NY65912 View Post
That's a different part number.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs
2005 E46 M3- Daily Beater - 3350lbs
Old 06-18-2014, 01:13 PM
So I guess the engine would run approximately 10% leaner under certain conditions, if one uses the 280150157 injectors?
Old 06-18-2014, 01:22 PM
TheSt|G's Avatar
Yeah no thanks. Always err on the side of rich. Rich is safe.
Old 06-18-2014, 01:30 PM
gtc gtc is offline
abides.
gtc's Avatar
Thanks, Mike. There are a few other people in the alternative injector thread running them also, which gives me some reassurance.
There seems to be a lot of incorrect information out there regarding injector flow rates.
Witch Hunter has a section of their site with actual test results, and the 157s and 158s flowed the same, though their tested resistance was different.
Graham
1984 Carrera Targa
Old 06-18-2014, 02:18 PM
Lots of info out there, go to this and more than a few others and draw your own conclusions. Most of the charts/info is gleaned from OEM sites. My only caveat is if there is a "thing to be sold" component beware because motivations can be different. Really only a few items need to be considered, ohms and flow at a specific pressure. My 028 150 165s are working fine and passed smog this year with flying colors.
Old 06-18-2014, 06:41 PM
Make America Great Again!
Rich Gas's Avatar
Hey Click...wasssss up. Been running the 360s for a year...with the weather warming up I set up idle to run too rich...surging a bit...so I dialed it back. I was getting a hint of raw fuel smell from the engine compartment blower area, connected to the exhaust. Nothing when I open the heater vents...soo (vacuum leak probably... Runs rich in winter...lean in summer)
I leaned it a bit and have been running it hard to see if it disappears...
The smell starts a few hours after sitting... New injectors, new fuel lines from Len, no evidence of a leak anywhere....I've read in another thread that sometimes the injectors leak through their core, down onto the heads...Fn phantom fuel smells....
We'll see how the leaning out does...the smell is kinda going away.
Old 06-18-2014, 07:32 PM
NY65912's Avatar
This is from Fuel Injector Cleaning Service and Flow Testing - Injector RX
fuel injectors flow rates
OHM’s CC/Min Lb/hr Bar
0 280 150 157 2.3 240 23 3
0 280 150 158 2.1 236 23 3
0 280 158 165 12.4 282 26.8 3 (Volvo Penta Marine Injectors)
P/No P/No g/min cc/min Ohms
0280 150 157 161 206 2,4
0280 150 158 179 229 2,4
0280 150 159 200 256 2,4
0280 150 160 155 199 2,3
0280 150 165 182 233 2,4
I hope this helps.
MikeČ
1985 M491
Old 06-19-2014, 04:11 AM
