Need a lead for front hub work
The outer races in my front hubs are no longer a press fit, as a matter fact, they are a loose fit. In doing my search, others have mentioned the bearing surface can be machined and a sleeve fitted. Can anyone suggest a reputable shop or person who has experience with this job and as always, is reasonable. Thanks
1986 Targa Guards Red 2021 MT09 SP |
Good used hubs should be easy to find.
It might be possible to machine them, either sleeve or install outer races with a larger OD. However, I would be leery of reducing material in the hub by any amount, especially if you take your car on the track. As John suggests, good used hubs are likely a better option, and I would strongly encourage you to have them checked by a company that does materials testing before you install.
I had exactly this situation happen to me a couple months ago. 944 Ecology was able to supply me with a good used hub for my own 944S that I used until Racers Edge had a new run of their billet hubs available. Expensive but cheaper than the consequences of a failure! Apologies, I don't know who makes such a thing for 911 series cars. Good luck, stay safe,
Kevin Catellus Engineering catelluseng@gmail.com http://www.catellusengineering.com https://www.facebook.com/catelluseng/ |
Thanks for the good advice guys.
