carrerarsr65
help with sc weight?
i have 79sc row car no sunroof,crank windows,interior stripped no rugs just 2 oem seats, ac gone, i need to guess at the weight to get a rough idea to set up rear susp. using will ferchs spring plate calculator.
as you can see she sits to high
Old 03-13-2013, 02:42 PM
carrerarsr65
tre bumper
oh ya also have a tre rs style fibreglass bumper the thing is like fibreglass art.
Old 03-13-2013, 02:44 PM
AutoBahned
RWebb's Avatar
just use the wt. in the Tech. Spec. Booklet and subtract the differential wt.s for replaced parts & the total wt.s for discarded parts
Old 03-13-2013, 03:38 PM
joe payne's Avatar
2250-2300 lbs. just a guess. Get it on the scales and corner balance it. It's worth it!
jtp911
Old 03-13-2013, 03:54 PM
Peter Zimmermann's Avatar
Don't you just want to turn the torsion bars until the inclination of the spring strut, aka radius arm, aka spring arm, is 35 degrees (34 with Bilstein shocks)? Start by disconnecting the shock (lower connection only) and trailing arm (at spring strut only) from one side, remove the lower rear bolt from the T-bar end cover, and measure the spring strut using a magnetic protractor, with it hanging free - it will probably be about 38 degrees. Put a protractor on the door sill to take into account the car not being level.
Are you sure your car is an RoW model? It seems too high...
Also, do a search for rear ride height adjustment...I think the reduced weight needs to be factored in. You will also, during adjustment, want to verify that your T-bars measure 24.1 mm. You can probably figure that your car weighs about 2600-something pounds, but you should find a local, to you, scale and weigh it.
Keep the Shiny Side UP!
Pete Z.
Old 03-13-2013, 04:32 PM
Air Cooled
Craig_D's Avatar
Those bumperettes are 7.5 pounds each... Removed mine a while ago.
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat"
'99 Honda VFR800Fi, '98 Honda SuperHawk
'88 Honda Hawk GT, '77 Honda CB750K Cafe
'69 Honda CL350
Old 03-13-2013, 04:35 PM
Senior Advisor
James Brown's Avatar
take it to a truck stop or DOT scales when closed, most leave the scales on and viewable through the window. Minerva blue, the best color!!!
08 Cayenne Turbo
Old 03-13-2013, 04:36 PM
