1975 porsche antenna
I am sorry about so many questions.
the po told me that when the radio was turned on. that the antenna would raise. I have searched the owners manual for a fuse relating to that. I am pretty sure this is a factory radio and antenna. any thoughts on where I should start? I am learning and very much appreciate your help brent
1975 porsche 911 silver anniversary edition 1967 camaro 1939 chevy 5 window business coupe |
ROW '78 911 Targa
What side of the car is the antennae on?
drivers side right on fender
I believe manual ant. were on left, auto ant. on right.
Banned
non-whiner
My 84 has an auto antenna on the passenger side.
Based on all this data, it seems the OP should have a manual antenna. |
Senior Advisor
should be a trigger wire from the radio that powers the antenna, check to see its there and gets power when the radio is turned on. Also, check to see that the antenna is a power unit, look in fender well
08 Cayenne Turbo |
I will do some more checking. like I said. the previous owner stated as soon as the radio was turned on. the antenna would go up automatically. so I need to do some looking for a wire
thanks for the advice maybe it was an add on. but I was looking for a fuse. it seems like porsche likes to tuck things away. hard to reach areas on these small cars brent
I was told tonight that this is a manual antenna. supposably there is a slot right in the top that takes a key of sorts to get it out. I just wonder why the previous owner said when the car gets started. or key in on position and radio on. the antenna would raise. he must have forgot by it being parked for so long. are these keys available? or was I told a wise tale
brent
ROW '78 911 Targa
The Keys are available on e-bay and other places. Search for Hirschmann antennae key.
Now you know why I asked you what side your antenna was on. Drivers side normally is a manual antenna. If you have a small screwdriver or a dime, stick it in the slot and using it like a prybar, wedge it in the slot and lift. Antenna will probably come up.
I am learning slowly timmy I do remember you asking. just not sure why
the po said it came up all by itself. crazy people thanks again brent
boy do I feel dumb. the antenna came right up. it certainly is a manual one.
thanks for the help guys. brent
76 manual antenna
any one know where i can by replacement parts for porsche antenna?
According to my restoration guide, "automatic rising antennas were available beginning with the 1976 Turbos and then became standard with the 1983 SC."
Senior Advisor
you can certainly add an auto one if you want.
08 Cayenne Turbo |
