DSM DSM is online now
DSM's Avatar
TEC3R - Full Sequential Mode - Cam Sensor Wiring?
Is anyone running a TEC3R in full sequential mode? If yes, did you have issues getting the cam sensor to not error out?
If you got it to work. Exactly how did you wire it? What pull-up resistor did you use? Did you connect the shield wire?
Thanks!
Old 04-09-2013, 04:45 PM
Uncertifiable!!!
Uwon's Avatar
You should talk to Richard Clewett at Clewett Engineering, The complete solution for ignition & fuel injection.
He is the Electromotive guru and has always been very helpful when I have had issues. Cheers.....
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 04-10-2013, 02:04 AM
83 911 Production Cab #10
JJ 911SC's Avatar
Originally Posted by uwon View Post
you should talk to richard clewett at clewett engineering, the complete solution for ignition & fuel injection.
He is the electromotive guru and has always been very helpful when i have had issues. Cheers.....
+1
Who Will Live... Will See
Old 04-10-2013, 02:06 AM
DSM's Avatar
I have been talking with Richard and yes he is a great resource. I have not solved my problem yet and would like others to share their experience and fix.
Old 04-10-2013, 08:07 AM
I would rather be driving
jpnovak's Avatar
Anytime you generate a low voltage signal you must shield the wire. I like to use teflon coated Coax wires for any VR sensor like a cam or crank sensor. In some cases this is not enough and you have to also build a small noise isolation circuit with a resistor in series and parallel to the signal wire and ground.
Old 04-10-2013, 07:29 PM
