77 CIS fuel lines
I cracked a line changing the fuel filter. I was able to repair it by cutting off the damaged section, using a heat gun on low and slipping it back together.that got me thinking about the age and condition of the rest of the lines. I had an 87 924s that burnt to the ground (mechanic who did a valve job and water pump failed to tighten the fuel rail.) Now I'm concerned about my 911. Pelican does not offer replacement fuel lines. Many of the pictures showing hot rods have s/s fuel lines. ?? What is the consensus on using slip fit s/s with hose clamps vs the unobtainable OE type of hard plastic lines? What experience have you guys had with the issue? thanks Kenny |
ROW '78 911 Targa
Search for posts by BoxsterGT he can fix you up.
i would not have heated it.
i put something like skin so soft or maybe, maybe wd40 on the fitting and slid it back on. i let it sit for a day or 2 then tried to twist it. it would not budge. i new it was goood to go. i wanted what ever it was that i lubed it with to evaporate. perhaps whyi usede SSS
1980SCMan
I replaced a few lines. There's a hose/line merchant in LA that had the right stuff. Had to buy 25 feet of it, but the price was reasonable. The lines have different sizes so you have to know what to ask/look for. For example, the line from the WUR to the fuel distributor is a different inner diameter than the lines from the fuel distributor to the injectors, but the outside diameter is pretty close to the same.
You don't heat them to get the fittings back in, but that's the logical approach. The actual method is much more straightforward. You tap them in. Here's my post showing how. You'll need some oak or hardwood and a few drill bits. Easy Fuel Line Repair For fuel lines, try http://www.mcmaster.com Last edited by Alan Lindquist; 03-13-2013 at 11:52 AM.. Reason: Added link for process and website |
PM sent
![]() This is what I have imported from Germany........... ![]() ![]() ![]() ![]() What CIS lines do you need? Len at Autosportengineering dot com
Obsessed
Not to take anything away from Len (many don't want to mess with it and he appears highly regarded)
But FWIW I recently found it's pretty easy to recreate these in your own garage if you get the correct line and take a few minutes to make a little jig.
'73 Mercedes 450 SL '75 911 Targa (long gone, sniff..) http://1975porschetargarebuild.blogspot.com My Targa Rebuild Blog "Life moves pretty fast, if you don't stop and take a look around once in a while you could miss it!" |
![]() Happy to offer the correct Polyamid tube by the Meter and the fittings individually to anyone who wants to do the assembly work themselves. Please email me for details. No PM's. Thanks, Len
