Hodgey's Avatar
Porsche Crest Opinions Needed On Shock Upgrade Please
All,
I come seeking opinons on my suspension refresh and shock replacement....
I am going to change the A arm bushings for neatrix / rubber not polybronze, and I will be changing the shocks front and rear also....
So, what are the pro's and cons of putting Bilstein HD on the front with Bilstein Sports on the rear versus HD all round or Sports all round?
Car is mainly street with plenty of DE action...
Thanks in advance
Neil
Neil
1987 Carrera, Grand Prix White, 2009 Carrera C4S, Meteor Grey Metallic
(X) [B] 2011 BMW X5[B]
'Success is not final, failure is not fatal. It is the courage to continue that counts'
Old 03-18-2013, 04:07 AM
Go-Kart Mozart
JAR0023's Avatar
This is going to sound like a canned response but have you searched the forum? I went through this last fall and while I had to wade through a bunch of "I like sports, no I like HD." type of threads there were several good long threads with lots of technical info where all the experts weighed in. Try a google search with this topic.
" site:forums.pelicanparts.com bilstein hd vs. sport, 911, pelican"
I have an 86 coupe, lowered, uprated torsions but a daily driver. I ended up with Heavy Duty all around. If I were in your shoes and using the car on the track I might have went to Sports in the rear. One thing that swayed me was a posting on one of the long previous threads that had the actual compression and rebound numbers for the rear Bilstein HD and Sports. IIRC the compression numbers were similar with the significant difference being heavier rebound numbers for the sports. I wanted the extra bit of compliance for the bumpy roads around here.
FWIW I'm very happy with the HDs. My car came to me with Koni reds up front but the PO had replaced the rears with KYB. A mismatch and the more I drove the car the more I felt it nagging me each time I drove. I won't pretend to know all the technical details but with the Bilsteins the car just works so much better as one unit.
-J
Old 03-18-2013, 09:55 AM
Go-Kart Mozart
JAR0023's Avatar
Start here.
Bilstein HD & Sport rates please.
More here.
Bilsteins: HD vs. Sport?
Shock rates, stock, HD, & Sport???
Bilstein and Sport Spec Query
Old 03-18-2013, 10:02 AM
Hodgey's Avatar
JAR,
I didn't intend for it to turn into 'one of those threads', but looking for real life feedback from someone who has actually done what I am contemplating.....
I appreciate the links....although I am still none the wiser....
Neil
Old 03-18-2013, 10:24 AM
Bill Verburg's Avatar
Originally Posted by Hodgey View Post
JAR,
I strongly agree w/ Chucks analysis in this thread
all the older design shocks had a linear valving setup that is just plain harsh, they will greatly benfir from a digressive setup matched to the springs/weight/ and purpose of the car they will be used in.
My C3 has stock Bilstein hd in front and sport in back, these shocks come w/ linear valves and it's great but is harsh. I re-valved the Cup/RSR shocks on my 993 w/ a digressive setup, the difference between the old linear valves and the new digressive valves is eye opening. The C3 shocks are slated to be rebuilt ASAP
Bill Verburg
Old 03-18-2013, 10:46 AM
GaryR's Avatar
Send a message via ICQ to GaryR
Hmmm... Makes me wonder what the mysterious "custom valving" is that Dan J. specifies for the Bilstein Sports on our heavy TB'd 911 race car's is... I'm going to move to an adjustable/remote res. at some point now that we know they are legal, but curious about what we have been running as they seem to work for the curb jumpers that we are.
Gary R.
Old 03-18-2013, 11:06 AM
AutoBahned
RWebb's Avatar
Can stock Bilstein HD or Sport shocks be changed to a digressive valving?
or would he have to buy entirely new shocks?
Old 03-18-2013, 01:00 PM
86FlatSix
JQ911's Avatar
JAR, not the hijack the thread, can you pm me your set up specially torsion bar numbers front and rear. I just lowered my car a little below euro height and still running on OE TBs and HDs. I would like to compensate on recommended TBs 22/28??? I don't intend to track nor DE just use it regularly for street. Thanks
74 BMW 2002 (rust rocket)
86 911 Coupe (weekend warrior)
09 997.2 C2 (semi-daily)
Old 03-18-2013, 01:07 PM
Air Cooled
Craig_D's Avatar
Yes they can. Chuck at ER revalved my Bilstein struts with digressive valving. I'm looking at the shock Dyno right next to me, even.
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat"
'99 Honda VFR800Fi, '98 Honda SuperHawk
'88 Honda Hawk GT, '77 Honda CB750K Cafe
'69 Honda CL350
Old 03-18-2013, 01:08 PM
Northern Motorhead
wildcat077's Avatar
I've been doing approx 16-18 track days yearly for the last three years and i find that i should have went with Sports all around rather than HD fronts and Sport rears ...
Although now i'm at the point of revalving due to all the other suspension upgrades you might as well go for Sports all around if you're going to be driving on the track with your car.
I asked all the same questions four years ago when i got my 911
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 03-18-2013, 01:12 PM
Air Cooled
Craig_D's Avatar
Here's the dyno read out that Chuck sent with my struts. You can see the digressive "knee bend" between 3.0-4.0 ips compression (top), and then between 4.5-6.0 ips rebound (bottom). This is essentially hydraulic lock, forcing to a freer valving at those damper-movement speeds.
'69 Honda CL350
Old 03-18-2013, 01:17 PM
Craig, so new Bilstein's are not digressive valving, but can be modified? What does ERP charge to modify new strut inserts bought from them?
1971 Light Ivory 911T - Gretchen - sold
Looking for Engine # 6114097
2010 Cayman
Old 03-18-2013, 02:01 PM
Von shocks are also an option. I'm thinking about going with them. Talk to Chuck.
Dean
2017 Toyota Tacoma TRD Sport(Hate it)
1965 Chevy Biscayne
Old 03-18-2013, 03:15 PM
I re-did the suspension when I bought my 911SC about 8 (?) years ago. It was sitting at factory SUV height for American bumper standards.
After reading lots of threads and paying close attention particularly to Bill Verburg, I chose to go to 22/28 torsion bars with Bilstein Sports front and rear. The car is lowered, I did a bump steer kit. I didn't use the polybronze bushings but think I used Neatrix, IIRC.
I have done lots of days on the track and it has been great. But the car is a street car and I love the setup on the street as well.
I hope this helps a little.
"Life is good"
Old 03-18-2013, 03:19 PM
Not to let any secrets loose but....
The best feature of all the newer shocks is that they all come w/ digressive valves, the external reservoirs are nice for heat control and an additional tuning tool
Bilstein has recently revamped their entire line, don't know if they changed the olde 911 stuff but they sure should have
Bill Verburg
Old 03-18-2013, 03:20 PM
Yes, Bilstein SD can rebuild them and maybe Chuck M does at Elephant too
monotube Bilstein/H&Rs are rebuildable, twin tube are not
Bill Verburg
Old 03-18-2013, 03:22 PM
Northern Motorhead
wildcat077's Avatar
Dean
Dean,
I was told by a good source that VON shocks are just a set of Bilsteins that have been precisely matched and valved more diligently than a regular set of Bilsteins ...
It's a lot cheaper to send in your own to have them rebuilt/revalved by one of the many shock gurus out there !
If i didn't already have a brand new set of Sports sitting in a box i would have sent mine out over the Winter.
Cheers !
Phil
Cheers
Phil
Old 03-18-2013, 03:36 PM
AutoBahned
RWebb's Avatar
Thx, Bill
After I bought new Bilsteins, I thought I'd never change the shocks during my lifetime, but...
Old 03-18-2013, 04:04 PM
Air Cooled
Craig_D's Avatar
I would check with Chuck Moreland at Elephant Racing, as I don't know if the new ones come stock with digressive valving, and if/what he charges to revalve Bilsteins bought through his shop. He's the man, he knows the whole deal.
'69 Honda CL350
Old 03-18-2013, 04:09 PM
Originally Posted by wildcat077 View Post
Dean,
Cheers !
Phil
Phil
Elephant will be raising the spindles on the struts and rebuilding the inserts. Vons for the rear are being considered because they are already shortened. Rebuilding the rears was my first thought, but the cost difference is negligible after having the bilsteins shortened. This is at least the direction Chuck pointed me.
Dean
1965 Chevy Biscayne
Old 03-18-2013, 04:24 PM
