Banned
Interesting valve adjust result.
After a valve adjust on my 3.2, the idle is about 100RPM higher when the car is warm. Cold idle is about 200 RPM higher.
If nothing was touched other than the valve covers and the valve adjusting bits, why would this be true?
Old 02-27-2013, 10:13 AM
Reiver
Reiver's Avatar
You tuned it up...now it breathes and exhales better is all.
Old 02-27-2013, 10:18 AM
Tired Member
DaddyGlenn's Avatar
How far off were the valve adjustments?
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 02-27-2013, 10:43 AM
Banned
It didn't seem like much. I *did* touch all of them up, however. It didn't seem like there was any glaring gaps or lack thereof. Maybe my unskilled hands can't tell???
Old 02-27-2013, 11:41 AM
redstrosekNic's Avatar
Does the car sound any different after the adjustment (more or less clatter)?
Dustin
Old 02-27-2013, 11:44 AM
You sure you didn't knock a vacuum hose loose?
Idle should be set by the ICV, not by 'tune of the engine'... unless the idle bypass valve was at it's limit of adjustment (too far open) and the ICV can't adjust the idle down far enough?
Chuck.H
'89 TurboLookTarga, 347k miles
Old 02-27-2013, 11:57 AM
Banned
Chuck.H
I could have, but I don't think so. Wouldn't a big vacuum leak after no vacuum leak make it idle lower??? And driveability hasn't changed.
It did have a bit of noise before the adjust, when the engine was cold. After, it was clatter-free. Sounds like a sewing machine when first started up.
Old 02-27-2013, 12:07 PM
E Sully's Avatar
Minor valve adjust by itself would not change the idle on the 3.2. DME controls it through the Idle Control Valve. You say the warm idle is 100rpm higher, fairly small change, but more relevant is the actual rpm. Assuming that you still have the stock chip installed, does it idle at 800 rpm?
I would make sure that the O2 sensor was still connected, those connectors tend to disintegrate from age and heat. I would then reset the base idle using the jumper in the port by the electrical panel. When the jumper is removed, see if it holds a steady 800 rpm, but drops a little when the oil cap is removed.
Ed
1973.5 T
Old 02-27-2013, 12:53 PM
Member 911 Anonymous
DRACO A5OG's Avatar
+1 check for vacuum leaks, buddy's 86 3.2 had a leak and he had higher idle, after vavle adjust and chts fix, it was higher so we checked his base idle and it was set too high, adjusted and all is well.
'85 Carrera Targa
PCA/POC
Old 02-27-2013, 01:37 PM
Guardsred911's Avatar
I had similar results, but on the '80 SC after dropping the engine, re sealing the triangle of death, new headers and exhaust, as well as valve...
I did have a backfire that popped the Pop - Off valve glue, which I fixed... but I looked closely for cracks and saw none
Similarly, I seem to be slightly higher... 200 at cold and 100 at warm... any suggestions on setting it?
(and yes, still scrolling through the list of posts, but this one seemed fresh and relevant)
So I just went into the garage and found the idle adjustment screw... I am wondering if I tweaked it when I dropped and reinstalled the motor... and all the other work I had been doing...
J
911 SC - 1980
911 S - 1977
Old 03-24-2013, 08:10 PM
Senior Member
Jdub's Avatar
It wasn't until I did a valve job on a Honda 400/4 (400cc 4cylinder) that I understood what opening up the valves meant. A choked (read: tight valve) drivetrain won't make much noise and won't idle well. Getting the recessed valves to now open at the proper adjustments will increase idle and let you hear the valves sing. The toughest valve job you will ever do is on a 911 tho. - no question!
'78 Targa in Minerva Blue
Old 03-24-2013, 09:04 PM
LakeCleElum's Avatar
I had the same result (higher idle) with a 911 once. The valves had not been adjusted in a long time and were on the tight side.
My theory: Valves weren't quite closing all the way and losing a little compression? It certainly was not a vac leak.
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 03-24-2013, 10:57 PM
