915 rebuild question?
Do i need to replace the stop and anchor blocks in the synchros or is the brakebands and synchro rings enough(the hubs show no signs of wear)? I cant find any tollerance data to meassure their wear, just a over all tollerance for the assembled synchro?
Old 10-02-2013, 02:34 PM
Peter Zimmermann's Avatar
Anchor & Energizer blocks are usually OK to re-use. I always replace them in the event of synchro failure (when the ring gets loose from the gear), but rarely if the synchro mechanism is still intact. Examine the block to band contact points for wear. Also, on rare occasion, you'll find a brake band that has wear grooves from the ID of the synchro ring, don't re-use those.
Keep the Shiny Side UP!
Pete Z.
Old 10-02-2013, 03:53 PM
Thank, everythink looks like new in transmission, the real reason i pulled it apart was to install new sychro rings for 1st, 2nd and install a lsd. But then i thought i might aswell install new bearings and all the rings and brakebands as long as i got the box pulled apart.
Old 10-03-2013, 04:51 AM
