Northern Motorhead
wildcat077's Avatar
Space ring for front spindle,need P/N
Hey guys,
Have my suspension apart and noticed the spacer rings on my front spindles show some wear.That is the race on the spindle behind the inner bearing.Does anybody have the P/N for this item ?
I need to order two of them asap from my local auto parts,i can't wait two weeks for Pelican ...
Thank you !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 03-25-2013, 07:41 AM
Air Cooled
Craig_D's Avatar
I had to order the same thing: Pelican Parts - Product Information: 901-341-623-00-M260
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat"
'99 Honda VFR800Fi, '98 Honda SuperHawk
'88 Honda Hawk GT, '77 Honda CB750K Cafe
'69 Honda CL350
Old 03-25-2013, 07:59 AM
Northern Motorhead
wildcat077's Avatar
Hi Craig,
I have the Pelican P/N but i can't wait two weeks for them to process the order and ship it to Montreal ... i'm off to my auto parts dealer with my strut and we'll see if we can come up with something !
Cheers !
Phil
Cheers
Phil
Old 03-25-2013, 08:12 AM
Not sure if the wear is all that important....as I see it on mine, the inner bearing should slip over the spacer and there should be no movement between that spacer and the inner race of the bearing. If there has been, I would think that it is the bearing that is beginning to sieze up which would then cause wear.
Given it is not all beaten up or heavily worn, why not just clean it up, maybe with some very fine sandpaper and use it? It is not a bearing surface that I can tell....
Dennis
Old 03-25-2013, 11:29 AM
Northern Motorhead
wildcat077's Avatar
Dennis,
For whatever reason,it is scored on the lower part,something i missed last Fall during my last track session where i couldn't see anything wrong.I had an issue with the inner bearing race spinning in my hub and it probably destroyed the spacer ring on the spindle.
Looks like it's a dealer only part and i might have to order from Pelican if i want two of them ...
Cheers !
Phil
Cheers
Phil
Old 03-25-2013, 11:35 AM
