The Bavarian
By-pass pipe instead of cat?
While tearing down my '81 engine (930/16 US version) I discovered that I have what I think is a by-pass pipe instead of a cat in my exhaust. Right? I didn't pay much attention to the exhaust since I have bought the cat a year ago and always assumed the car would have a cat. All the CIS components are there including the O2 sensor, and the system is perfectly working in closed loop mode (term?).
As a European I'm not familiar with US regulations. I have always read about the strict US smog tests (visual and measurement) and I'm now wondering how the car may have passed these tests. The by-pass and the bolts are such rusted that it must have been there at least the last ten years. The car was last registered in Wisconsin, and I have a bill that shows the O2 sensor has been changed in 2011.
Any thoughts???
Thanks, Manfred
Old 03-28-2013, 11:49 AM
Checked out
McLovin's Avatar
Smog tests are a state-by-state issue. The rules in each state are different.
Many/most states no longer smog test a car that old.
Old 03-28-2013, 11:53 AM
schumicat's Avatar
that is a bypass. in Europe they had a premuffler in that spot; it was a straight through design but had an outer tube and perforated inner tube and reduced the sound a little (probably tuned the sound more than reduced it). only some states have smog testing, like California. most in the South don't.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 03-28-2013, 12:08 PM
