Porsche Crest Why is my 86 runs like crap,rough idle when cold poor performance slughish
My 86 Carrera runs rough I got it that way ,I replaced the MAFS ,O2 sensor ,I even installed a set of racing headers and a M&K GT3 muffler ,not much improvement!
It feels like perhaps has a vacuum leak or...? Suggestions ? Much appreciated !
Thanks Pelicans !
Old 03-28-2013, 06:01 PM
plumb4u2's Avatar
you don't provide much input on the problem but from what I get from your description sounds like vacuum leak
Have you searched for leaks with carb cleaner?
Justin
84 Carrera Targa
98 F-150 4x4
Old 03-28-2013, 06:09 PM
DCR Rides
mdripley's Avatar
make sure both fuel pumps are working. My 930 ran like crap on only one pump.
87 930 turbo coupe 3.3L , 4Spd 930 Trans w/LSD , mostly stock for now
Old 03-28-2013, 06:33 PM
plumb4u2's Avatar
two fuel pumps?
Justin
84 Carrera Targa
98 F-150 4x4
Old 03-28-2013, 06:44 PM
Porsche Crest rough runing 86
I don't think the 3.2 Carreras has tow fuel pumps ?!
It idles very rough when cold, I know it doesn't have a Cold Start Up Valve so what could be the problem then? It feels very sluggish and low on power.
Old 03-29-2013, 01:23 AM
plumb4u2's Avatar
our 3.2s do not have two fuel pumps!!
you need to check for vacuum leaks and also have your AFR checked
Have you checked that you ICV (idle control valve) is working properly? it may need a good cleaning
searching on here for "3.2 idle" will give you many hrs of reading
Justin
84 Carrera Targa
98 F-150 4x4
Old 03-29-2013, 05:09 AM
Clean the injectors first. If that doesn't solve it then start checking sensors and for vacuum leaks.
69 911 2.3Ez
85 928S
Old 03-29-2013, 10:20 AM
Porsche Crest Afr ?
Pardon my ignorance but what is AFR ?
I think I have to take it to the shop ?...Only one problem ,there aren't any (Porsche mechanics)worth their beans in Southern Nevada aka Las Vegas.
I think I have to drive al the way to Cali for that ...
Thanks !
Old 03-29-2013, 06:29 PM
Grappler
Rodsrsr's Avatar
Air Fuel Ratio.
Grappler
Know Gi / No Gi
1976 RSR Backdate (Turbo 3.2)
Old 03-29-2013, 06:33 PM
E Sully's Avatar
Have you made sure all the basic settings are correctand sensors working? See my post here.
East Coast 911 new to California, takes a while to crank up
Ed
1973.5 T
Old 03-30-2013, 06:09 AM
