Elombard's Avatar
Any Idea why my clutch keeps going out of adjustment??
73.5 911T with 78 SC motor. It was grinding real bad into first and reverse. I adjusted the clutch and it was like a dream!! now a week latter and it is doing the same thing? Is the clutch tube damaged (rust) or something? Car has no rust otherwise.
CLutch is a few years old but low miles. Looks like cable was replaced at the same time.
Old 07-10-2002, 07:35 PM
marcesq's Avatar
Here are the possible culprets:
Cable is stretching due to fraying;
Cable end is coming loose (rare);
Hole in Clutch arm in pedal cluster where clutch cable attaches is wearing through;
Pin that goes through clutch pedal and into Clutch arm is giving way and will eventually break leaving pedal on the floor;
Pin securing clutch shaft to fork in bell housing going bad (big trouble, .50 part but engine comes out);
Pedal bushings are going bad;
Clutch arm getting chewed up because bushings are bad.
There may be others, but that is all that I can think of.
Good luck.
'94 CMC Firebird Trans Am
'86 951 LS1 (C-2) Gone
'77 911 3.2 (C-1) Gone but not forgotten.
http://www.pelicanparts.com/MotorCity/marcesq1
http://www.youtube.com/user/958Fan#p/u
Old 07-10-2002, 07:48 PM
