ask for obx header
hi guys . i want to upgrade my 80 911 sc stock heat exchange to a header. because i remove the heat and air con. my question will this OBX Racing Exhaust Headers Porsche 911 Carrera RSR 3.0L fit on my 911sc ? i know i need new muffler . but just want know will fit or not . or do i have to change any oil line ? thank you
Old 03-30-2013, 07:24 PM
carrerarsr65
oil line
ya i have 79sc and did a heat delete u must change 2 oil lines pelican has them they r noted as backdate oil lines good luck
Old 03-30-2013, 10:26 PM
Diss Member
Quicksilver's Avatar
OBX is cheap but I would do a search on quality...
That said, if you have to buy a replacement set you would probably still have spent less then a quality set of headers.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 03-30-2013, 11:28 PM
hi carrerarsr65 can you pls tell me what is the part number for the 2 oil line , i could not find on pelican . thank you for ur guys help
Old 03-30-2013, 11:54 PM
Oil lines for SSI/headers conversion.......
KJ9438,
These are the two (2) oil lines needed for SSI/headers conversion.
These are available from our host at reasonable prices. Spent $130 for 2 used oil lines years ago and today they are about $200 new.
Oil lines:
911-107-729-10-M127
911-107-739-10-M127
Tony
Old 03-31-2013, 06:10 AM
Preferred pronoun:Maestro
Norm K's Avatar
I might get flamed for this but I just can't help myself. Posting here isn't like texting (although I'm a believer that, brevity be damned, even texts should contain decent grammar!) and this isn't a Civic forum. How about at least trying to write the way you know your grandmother would want you to?
When in doubt, use overwhelming force.
Old 03-31-2013, 06:27 AM
gearhead
Nkowi, I agree with you but take a different approach. If I have to struggle to understand what was written I move on to the next thread and don't contribute my knowledge. While your efforts are well intentioned in my experience they frequently are met with a defensive argument.
Old 03-31-2013, 07:39 AM
Diss Member
Originally Posted by boyt911sc View Post
KJ9438,
Oil lines:
911-107-729-10-M127
911-107-739-10-M127
Tony
A good option is to use the Elephant Racing Universal Crossover Pipe instead of the 911-107-739-10-M127. It will work with both types of exhaust routing. No more switching oil lines to switch exhaust systems.
Old 03-31-2013, 07:56 AM
