Weekend Mechanic
vulcan300's Avatar
What is this connector supposed to attach to?
Hello all. I have a mysterious connector in the engine bay of my car and I'm hoping someone can tell me what it should be connected to. It is located right below the ignition coil. It has three wires; Red/White-Stripe, Black/Yellow-Stripe,Red/Black-Stripe. I thought it was for the engine compartment light but I believe that connector is to the right of the air filter. I've attached a picture of the connector. Thanks for your help!!
86 911 Carrera Targa
Old 03-31-2013, 11:36 AM
rsscotty's Avatar
Usually, that connector shape goes to the oxygen sensor. I don't have my wiring diagram at home to verify the wire colors.
Old 03-31-2013, 11:43 AM
Weekend Mechanic
vulcan300's Avatar
Oxygen sensor was my first guess as well. But the Oxygen sensor connects to a connector underneath the fuel filter. The yellow arrows point to the connector from the oxygen sensor
Old 03-31-2013, 12:57 PM
Cooper911SC's Avatar
It's a test connector.
On CIS cars you can use 2 of the ports with a Dwell meter to set the CO on the car.
Old 03-31-2013, 01:04 PM
plumb4u2's Avatar
I just looked my 84 does not have that connector
Justin
84 Carrera Targa
98 F-150 4x4
Old 03-31-2013, 02:23 PM
Rear window defroster. Blk/yel feeds the third brake light. Final answer.
Old 03-31-2013, 04:11 PM
vince_wa
Rear window wiper - I recently disconnected mine when I removed the whale tail
Garage - 1987 911 widebody
Old 03-31-2013, 05:53 PM
Certified User
billjam's Avatar
Definitely final answer. Just been working on this in my car ('88).
Bill
1988 Carrera - 3.6 engine with ITBs, COPs, MS3X
2024 Macan S
Day job ... www.jesfab.com.au
Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S
Old 03-31-2013, 06:47 PM
Weekend Mechanic
vulcan300's Avatar
For the targa the Rear Defrost in the wiring diagram shows Red/Blk and Red/Wht with no wire for the brake light. The rear wiper is shown as having Red, Brn/Blk, Red/Black which seems closer. The blk yellow is throwing me off. I will check tonight when I'm working on the car. Thanks for all the feedback!
Old 04-01-2013, 03:36 PM
