Amat Victoria Curam
Intermittant starting
I have a 3.2 conversion in a 1977 Targa. The car has run perfectly for years and now starting intermittently. I swapped out the DME twice, checked for fuel smell at the tail pipe. When it turns over it runs perfectly. Any Ideas?
Old 04-03-2013, 05:48 PM
schumicat's Avatar
that is common failure mode for a starter. describe what happens when it doesn't start.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 04-03-2013, 06:35 PM
muck-raker
kidrock's Avatar
DME relay
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 04-03-2013, 08:07 PM
Vereeken's Avatar
Most likely the starter. When it does not start it is the result of heat sink or the starter that is sitting on a bad patch of the windings.
I believe you will be able to push start the car if it does not start on the starter. If that is the case that should rule out the DME and point you to the starter.
My dad always found an excuse why not to buy a Porsche, so I guess I am all out of excuses.
Old 04-04-2013, 01:35 AM
Amat Victoria Curam
I have a new starter, and it turns over nicely, it just doesn't fire all the time. If it starts, it fires quickly and run perfectly. I have a new ignition switch as well.
Old 04-04-2013, 01:49 AM
Vereeken's Avatar
Not the starter in that case.
Old 04-04-2013, 06:36 AM
OsoMoore's Avatar
Perhaps the fuel pump is intermittent? Try swapping fuel pump relays. Also try pulling an injector and checking for consistent spray.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery.
Old 04-04-2013, 06:46 AM
