(man/dude)
Jonny042's Avatar
Can you identify a "big port" CIS system from this pic?
Not really up on my CIS, other than to know this car has old style plastic lines. Is it possible to tell from this pic if this is a 78-79 CIS system?
Thanks!
Old 04-07-2013, 07:06 AM
Speed Dog's Chauffeur
Dodge Man's Avatar
Motor # or Visual check against an 80-83 or flanges
Kind of looks like my 80 3.0 with high velocity(small runner 80-83) in the picture. Check the motor # with charts found here on Pelican is an easy option(preferred). The exhaust flanges for big port are also the thin flanges unless changed by PO. If it is a 78-79 US the look for the SMOG Injector ports (probably blocked off) & long stud AIR Pump mounts on the top side of case. Best of Luck
Old 04-07-2013, 07:20 AM
what does the stamping say ? 2R means small runners and 4R large
80SC (ex California)
Old 04-07-2013, 09:04 AM
El Duderino
tirwin's Avatar
Thanks!
No idea but that is a wacky looking air box! Never seen one drilled out like that before. Is that an attempt to lighten it? (I kid, I kid...)
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 04-07-2013, 09:08 AM
(man/dude)
Jonny042's Avatar
2r
Thanks trond that's very useful, looks like 2R so that's good news, It's a 78 but has the non-original motor so just checking that out. Who knows what else could be hiding under there!
Old 04-07-2013, 11:50 AM
(man/dude)
Jonny042's Avatar
Oh I know...... the current owner/seller is not very knowledgeable when it comes to these cars. He is under the impression the car makes 300hp (it must be true because it's in the description on his ad )
So, each one of those holes must be worth 5hp. And a K&N filter another 20. I'll give you a good deal on the airbox if you want it!
Old 04-07-2013, 11:55 AM
Brown747's Avatar
[QUOTE
So, each one of those holes must be worth 5hp. And a K&N filter another 20. I'll give you a good deal on the airbox if you want it![/QUOTE]
and another 10hp for the FRAM filter...
1978 SC coupe #1834
Old 04-07-2013, 12:07 PM
Scott R's Avatar
Run away. Right rear quarter has been replaced.. incorrectly. Along with other things.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 04-07-2013, 12:29 PM
(man/dude)
Jonny042's Avatar
Hmmm.... care to elaborate? I know there are a lot of non-original details here, that don't matter to me or bother me. But I was under the impression the basic body structure was good. I'll attach a few pics.... maybe start a new thread?
Oh and ps it's a non-sunroof car, if you are noticing the lack of sunroof drain?
Old 04-07-2013, 02:24 PM
(man/dude)
Jonny042's Avatar
Started a new thread.....
Help Pick apart a potential purchase?
Old 04-07-2013, 03:06 PM
Josh D's Avatar
Quote de trond
Look at the engined type number near the oil temp sending unit to know what motor you have. And just curious, why do you want the small port head if you're building a hot rod?
Old 04-07-2013, 06:08 PM
Scott R's Avatar
That area is where the replacement quarters line up. And that one looks like it was done by a welder with a bad case of the DT's. See below:
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 04-07-2013, 06:32 PM
(man/dude)
Jonny042's Avatar
Brain Fart..... misread the info from Trong's post above.
Oh well, in the end the balance still falls in favor of buying the car, warts and all. Even if it's a "small port" motor I plan to go to an ITB setup, regardless, so it's really just a matter of porting (or better yet finding a set of carrera heads!)
And the body? Well, I'll take the good with the bad, I guess. The car is cheap enough that anything I find that ISN'T wrong with it, will be a bonus!
Old 04-08-2013, 04:47 AM
(man/dude)
Jonny042's Avatar
Hi Scott, Thanks for the pic... to my eye the white car is a heck of a lot more "factory" looking that the one in your pic - at the factory they didn't bother dressing the welds as yours have been done.
I take it your quarter panel has been replaced?
Old 04-08-2013, 05:28 AM
(man/dude)
Jonny042's Avatar
here's another example, from another thread of a "factory" job... best I could find in a few seconds of searching
Rust from sunroof drains?
Old 04-08-2013, 05:31 AM
Scott R's Avatar
No, never replaced. And the only ones I've seen that look like yours have been in an accident.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 04-08-2013, 07:03 AM
CorsePerVita's Avatar
I gotta ask, what's up with twisting the air box straps?
1970 Porsche 914 1.7L, 1982 Porsche 911 SC Targa, 1977 Porsche 924, 1979 Porsche 924, 1999 Ducati 900SS
Old 04-08-2013, 07:17 AM
(man/dude)
Jonny042's Avatar
I'm guessing that's because they stretched over time and became loose? Just another thing to make me laugh - I am sure there will be many.
Old 04-08-2013, 07:51 AM
(man/dude)
Jonny042's Avatar
I found one more pic (this time of an 18k mile survivor) -
Is yours a Targa or Cab by chance? Maybe that seam was handled differently on those models?
Old 04-08-2013, 08:11 AM
