Steering too light?
Hello all,
I am new to the 911 world and I have a question regarding how the steering should feel. I purchased a ’70 911E recently and the steering just feels too light to me. There really is very little resistance and I higher speeds (50 mph and above) the steering wheel moves side to side a little. It doesn’t move violently like the wheels are out of balance, it feels like the car want to wander but doesn’t. It feels like the road could be causing this feeling but it’s on any road I travel. I constantly feel that I need to correct the steering but it seems to run in a straight line. I probably need to take it in and have the alignment and balancing checked. Is what I’m describing sound normal? Regards Chris |
sounds like an alignment issue...too much toe out.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
Senior Member
+1 on alignment. Be sure to scope out your balljoints, shocks, etc. on the front end as well - if the PO has not already replaced the bushings, etc. you might consider that prior to an alignment. A 911 feels differently with the 20+gallons in the tank as well, but that breadth of feel (Full > Empty) should never make you feel like your car is wandering.
'78 Targa in Minerva Blue |
Air Cooled
It's the Caster angle. It's too steep. When Caster is too "raked", then steering is very heavy. Too steep and it feels very light (like it wants to shake its head or do a tank slapper).
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat" - - '99 Honda VFR800Fi, '98 Honda SuperHawk '88 Honda Hawk GT, '77 Honda CB750K Cafe '69 Honda CL350 |
Could be numerous things, alignment, ride height, balence, bushings, etc.. Easy things first, like alignment. But if you want to drop it some, now is the time. Does it have a tail, and no front dam?
72 911 Although it is done at the moment, it will never be finished. |
The ride height appears, visually, to be right. It doesn't have a tail but it does have an early 911 "S" front bumper.
Chris |
Banned
see, thats ur first problem. get rid of that heavy steel factory 's' bumper. put it out on the curb and watch it till i get there. wait, where do u live?? ( kiddin ). youll get plenty of good advise here and bad jokes from me.
912 Geek
Also check u-joints in steering column, inside smuggler's box.
Red Line Service
All of the above are "valid" points, but start with BASICS, have you CHECKED YOUR TIRE PRESSURES? 911's don't like more than 29 lbs in the front, very early cars you can run as low as 26. If you're running anything over 29 it will feel like what your describing.
Marc Bixen/Red Line Service West Los Angeles, Ca. www.redlneservice.net / info@redlineservice.net Podcast:"Marc Bixen Live" https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA |
I have them at 32 psi. I'll adjust the pressure and see. It's still probably a good idea to have it aligned anyway.
Thanks for all the advice. Chris |
AutoBahned
32 is fine
but rears should then be at 34 |
More like toe problem to me. If I am correct, the more caster you have, the more straight it goes, and the harder to turn.
Fat butt 911, 1987 |
here' s the suspension specs
Air Medal or two
Maybe one more thing.....................
You know the Prior owner? He may have it set up for his kind of driving......It may be well sorted.....it may be its just NOT what you are used to?
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
The previous owner basically flipped the car and the person before him monkeyed a lot of stuff up so I've been trying to correct what he's done. Unfortunately., I don't have a lot to compare it to. Afterburn 549 may be right that I may not be used to it but if feels different from any old car I've driven. I own a '59 Porsche 356 and the 911 steering is lighter than the 356 which seamed odd.
Chris |
Air Medal or two
At 60/40 weight ratio there is not a lot of weight on each front tire either
