CorsePerVita's Avatar
Coils...
So the resistance check on my coil is out of spec and my car was missing badly. Upon checking the rotor and cap, I can see why.
Obviously going to go through the ignition "while I'm down there" - but my coil doesn't look like the coil I see on pelican. It's a black bosch coil. I suppose I can snag the part # off of it.
Anyone recognize it?
Do I just need one of these? I'd assume so.
http://www.pelicanparts.com/cgi-bin/ksearch/PEL_search.cgi?command=show_part_page&please_wait=N&make=POR&model=911M&section=ELignt&page=10&bookmark=36&part_number=901-602-502-00-M14
1970 Porsche 914 1.7L, 1982 Porsche 911 SC Targa, 1977 Porsche 924, 1979 Porsche 924, 1999 Ducati 900SS
Old 04-09-2013, 07:27 AM
muck-raker
kidrock's Avatar
the black coil is probably the original German Bosch coil. Unfortunately, they are NLA and we are forced to buy the considerably inferior Brazilian Blue Bosch coil.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 04-09-2013, 08:45 AM
Scott R's Avatar
Yup that's the correct coil. NLA as mentioned. MSD + MSD coil is a good option.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 04-09-2013, 08:48 AM
Seems an awfully expensive solution vs just buying a coil. Is the upgrade a "significant difference" ? This is also my daily driver, no tracking with it, no autocross. Not sure if I want to deal with setting up a trigger system right now lol.
Old 04-09-2013, 09:20 AM
What is wrong with the blue coils exactly vs the original coils?
Old 04-09-2013, 09:23 AM
What a clean SC. Congrats!
Old 04-09-2013, 09:27 AM
76 911S Targa
You get our interest and then don't post pics of the cap and rotor? What was wrong with them? Badly worn? Big cracks? Gray fuzzy monsters on the contacts?
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 04-09-2013, 09:28 AM
Scott R's Avatar
No, not an "upgrade" just easier to get parts for at this point.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 04-09-2013, 09:34 AM
I'll snag some up close pics later, this is the only one i could find now.
Basically resistance test is out of spec when I tested it with a multimeter. It was teetering last year on the resistance between "in spec" and "almost there" it's now not there. Developed a bad miss and crap idle. Rotor has only been in there a year and looks like it's been running hot (discolored on the edges, lots of wear).
Old 04-09-2013, 09:35 AM
If you take the cap off, can you wiggle the rotor back and forth? In other words, is there play on the rotor shaft?
Old 04-09-2013, 10:36 AM
Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
MSD blaster coil vs. Bosch coil
Warren Hall recommended the MSD High-Vibration PN8222 back in this thread. I used this coil for a couple of years without issue with my stock CDI box. Wayne has them for $55.
Porsche 911 & Carrera Ignition - Page 11
things that made my SC run better ignition-wise in the order i did them:
Cap, rotor, green wire
then
disasemble and clean dizzy, timing set at WOT
then
magnacores and new plugs
I didnt notice a difference with the blaster coil, so now I have a spare
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 04-09-2013, 12:20 PM
ROW '78 911 Targa
timmy2's Avatar
MSD blaster II coil works great on mine.
Old 04-09-2013, 12:46 PM
Functionista
manbridge 74's Avatar
I wouldn't be so quick to condemn my coil until I ...
-tested it out on another well running car
-checked resistance values of another coil off a well running car
-realized resistance values change a lot with temp so making sure coil is room temp or higher before testing.
-made sure it was hooked up with correct polarity
-realized that most coils fail when they get too hot, so running well when cold as opposed to then running bad after warm-up
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 04-09-2013, 02:25 PM
Senior Advisor
James Brown's Avatar
you did both tests, what were the results
08 Cayenne Turbo
Old 04-09-2013, 03:04 PM
El Duderino
tirwin's Avatar
Let's be careful not to re-ignite The Great CDI vs Multi-Spark Debate of Aught 12, mmmmmk?
Old 04-09-2013, 03:11 PM
AutoBahned
RWebb's Avatar
which one is better?
Old 04-09-2013, 03:22 PM
El Duderino
tirwin's Avatar
Funny guy, RWebb!
Old 04-09-2013, 03:24 PM
and while we're there, what's the best oil?
Old 04-09-2013, 05:07 PM
I like the Cool Collar...
Old 04-09-2013, 08:52 PM
Senior Advisor
the msd "BLASTER!!"® coil has a sticker on it that is removable, slap a Bosch® one on it and your good to go
08 Cayenne Turbo
Old 04-09-2013, 08:59 PM
