nicfranc's Avatar
CrossOver Pipe Flange Question
I am replacing my Cat with a M&K pre muffler on my 1980SC
The Flange on my Cat is rusted out and i am not sure if the crossover flange will hold up.
Is the flange on the crossover pipe separate or an integral part of the pipe ?
I am wondering if I need to buy a crossover pipe.
1980 911sc Petrol Blue Metallic Targa, 300,000 + miles
M&K Pre Muffler + M&K 1 in & 1 out Sport Muffler
Previously owned and rebuilt:
60's VW Bugs, Buses & Ghias
Old 04-10-2013, 05:20 PM
plumb4u2's Avatar
I just did this same project and my flanges looked as bad as yours
the flange for crossover pipe is part of the pipe it does not come off
I had to cut all bolts off with dremel tool and hammer out remaining studs then I used the dremel to clean up flange face to make a good seal
I doubt you would have to buy new crossover
Justin
84 Carrera Targa
98 F-150 4x4
Old 04-10-2013, 05:30 PM
From the looks of it you should be ok. I had the same issues with my 84 Carrera and I dremeled off the rusted bolts and a couple taps with the hammer got them out. Then I had the whole exhaust bead blasted and I painted it with a little high temp silver paint. New gaskets all around and no worries!
Rick
1984 911 coupe
Old 04-10-2013, 05:41 PM
nicfranc's Avatar
Well that would be nice if I did not need a new crossover pipe as they are $235 new.
At least some of the bolts and nuts have pretty much disintegrated.
I am not looking forward to cutting out the remaining bolts.
There does not seem to be a whole lot of room to get a Dremel up in there even with the flex extension.
Old 04-10-2013, 05:45 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Don't be afraid to put a little muffler seal goop on it from the local parts store when re-assembling. I played hell with sealing mine with the copper gaskets that came from Fabspeed when I installed their pre-muffler. Believe I just put new OEM gaskets on with a little dope. No problems since that I can tell.
1981 911SC Targa
Old 04-10-2013, 05:48 PM
plumb4u2's Avatar
I did not use the flex extension
I have a lift so up went the car and off went the wheel and there is plenty of room
Just take your time and have fun it's not that bad of a job
Justin
84 Carrera Targa
98 F-150 4x4
nicfranc's Avatar
What kind of bolts did you use ?
1) stainless
2) copper nuts
3) steel w/anti seize
Old 04-10-2013, 06:15 PM
nicfranc's Avatar
Ok, Thanks for the help I will give it hell.
Old 04-10-2013, 06:37 PM
nicfranc's Avatar
I am not familiar with this product.
Do you apply it right over the gasket on both sides ?
What kind of hardware did you use ?
Steel, stainless, copper nuts, anti sieze ?
Thanks for the input.
Old 04-10-2013, 06:41 PM
nicfranc's Avatar
Exhaust Leak & Gurgling on deceleration.
Maybe this exhaust leak explains the gurgling & popping when I let up on the
gas.
Old 04-10-2013, 10:36 PM
