T77911S's Avatar
i need washers
i need the 3 washers that go on the cam line on the right side. i have a very bad leak from where the "restrictor" bolts to the cam housing. it looks like i have 2 different types of washers there. one is the aluminum type and 2 are harder.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 04-13-2013, 10:35 AM
Red Line Service
Marc Bixen's Avatar
The correct factory washers are actually steel, pt #900-123-005-00. You should be able to get them through a local source/dealer, retail $2.04 each. I like to put a light coat of Loctite 574 (case sealant) on the threads of the restrictor fitting that screws into the cam box. Use caution tightening this fitting as it is fine threads going into aluminum.
Marc Bixen/Red Line Service
West Los Angeles, Ca.
www.redlneservice.net / info@redlineservice.net
Podcast:"Marc Bixen Live"
https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA
Old 04-13-2013, 11:29 AM
Taking it apart is easy
Jerome74911S's Avatar
If you are looking for these, I just installed copper ones, as recommended by PP.
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 04-13-2013, 11:46 AM
T77911S's Avatar
those 2 and the one on the cam housing.
2 i think are steel, one was aluminum. i thought all 3 would have been aluminum.
RACE CAR:: sold
Old 04-13-2013, 12:31 PM
Aluminum or Copper crush washers........
Ty,
If you want to stop the leak, use the soft material crush washers like Al or Cu. I've never used steel crush washers at these fittings. Go visit your local auto dealers (Japanese or European cars).
Tony
Old 04-13-2013, 01:03 PM
Otto H. Wegkamp
Guest
Posts: n/a
I also would recommend copper. If no new ones are avaiilable, copper washers can be reused after soften them by heating them up until they are glowing.
Otto
Old 04-13-2013, 01:34 PM
Brown747's Avatar
Also...be careful to not over torque as the hollow bolt will snap. Ask me how I know!
Thor
1978 SC coupe #1834
Old 04-13-2013, 01:35 PM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Otto
Then plunge into water while glowing, annealing copper, backwards from steel!
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 04-13-2013, 02:49 PM
T77911S's Avatar
i need some part numbers for the aluminum washers. this leak is driving me nuts.
i think i was leaking from the studs and the oil line. the valve cover looks better, now the oil is just running down the valve cover.
RACE CAR:: sold
Old 04-14-2013, 05:36 PM
Member 911 Anonymous
DRACO A5OG's Avatar
+1 what Master Marc wrote, DO NOT OVER TORQUE, IT WILL LEAK AGAIN. ask me how I know
'85 Carrera Targa
PCA/POC
Old 04-14-2013, 05:41 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
I have used sealing washers for years...mostly copper....the kind with a series of indented rings in the sealing surface.
I get them from McMaster-Carr...by the 100 box.
Using old washers is for amateurs.
The cost of these things is so small...there is no excuse for re-using any of them.
Bob
Bob Hutson
Old 04-14-2013, 05:58 PM
Speed Dog's Chauffeur
Dodge Man's Avatar
Reuse?
M2CW I replace the 2 "soft" sealing washers at oil changes so why try to reuse the washers on a critical oiling line fitting if you do not have to? I look at in terms of $10 worth of washers vs. a cam meltdown or oil fire. Since the factory washers do not seal because the surfaces are "not new" then go for the softer aftermarket Al or Cu washers. Check with our host. I broke a few of the hollow "banjo bolts" turning wrenches in my youth so as Pelicans above stated "watch your torque". An inch-pound torque wrench may be in order. The aluminum threads in the cam towers will not like excessive torque. Fine threads handle more load but require more care. Best of luck.
Old 04-14-2013, 06:53 PM
T77911S's Avatar
trying to get new ones, but need a number or source.
RACE CAR:: sold
Old 04-15-2013, 04:48 AM
Spiderman
Jesse16's Avatar
crush washers
This is where you want to get a lifetime supply.
McMaster-Carr
You'll have them in 2 days, standard shipping every time. You have to know the size or just get several boxes!
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 04-15-2013, 05:48 AM
T77911S's Avatar
awesome. thanks. M10 i would guess. it will be nice to stock up on some others too.
RACE CAR:: sold
Old 04-15-2013, 08:17 AM
Spiderman
Jesse16's Avatar
washers
I've still found it to be less $$ to get the drain plug sizes locally but smaller and odd sizes probably aren't at the FLAPs.
Old 04-15-2013, 08:45 AM
T77911S's Avatar
i wish wayne would put together kits with some of these washers.
RACE CAR:: sold
Old 04-15-2013, 10:00 AM
dshepp806's Avatar
Now THAT'S a great idea! Kits,...if thorough, good to have around!
Thanks!
BEST!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 04-15-2013, 03:13 PM
T77911S's Avatar
i hate to reuse copper/alu washers but where to get them i dont know. i have had my injectors out of my 930 twice this week and had to reuse those copper washers. when you dont do this for a living and you need to do something like pull injectors you have to do with what you have at hand at the time, which is nothing.
RACE CAR:: sold
Old 04-16-2013, 03:09 AM
