1.) Yes, convert to R-134a. 2.) add a trinary pressure sensing switch to the high pressure side. 3.) Use the switch to control the on/off cycling of the compressor. 4.) Mount at least 2 fans to suck airflow downward through the rear lid condensor as controlled via the pressure switch 2nd function. 5.) Use a TDR, Time Delay Relay, to allow those fans to continue to run under the control of the 2nd pressure switch function for up to 10 minutes post engine off. 6.) A reasonable, legal, tinting of the side and rear windows will always be of help. The primary function of the pressure switch will be to prevent the compressor from "over-running" and thus over-pressurizing the system. The secondary pressure switch function will prevent the over-pressurization of the system due to latent engine heat. |
I'm in the middle of installing my new Kuehl setup from Griffiths and went through the same process as you a few months ago - trying to balance what I wanted to accomplish with the costs. What I knew I didn't want to do was have to keep playing with the system, incrementally trying to get to what I wanted.
With that in mind, I figured there was little point in re-using components that were now 31+ years old. The A/C in my car hasn't worked since I bought it 12 years ago, and I suspect it stopped working long before that so why try and make this old crap work again?. So I went with all new components except the rear deck-lid condensor, including the rear fender mount condensor. For good measure, I also decided on a new Wirbelsturm evaporator motor to push more air, as well as the Kuehl fan switch and center vent replacing the bowtie. Replaced the thermostat switch as well for good measure. At this point in the installation, I can tell you that the evaporator motor and switch upgrade alone rock! Just having a lot more volume of air moving a lot faster at you makes a nice difference. Once the A/C system is charged and working, I have absolutely no doubt that I am going to be a lot more comfortable in the car. I've got the new evaporator (incl fan and switch), front and rear Kuehl condensors, and driver side hoses all installed. Still have to hook up the new Kuehl condensor electrics, evaporator in/out hoses and compressor, so I've probably got a couple more evenings to put into it. Then I have to wait for warmer weather to get it all charged up - and will post results if anyone cares to see them. So, my opinion would be if you want to try and do it in stages, at least start with new basic components (evaporator, front condensor, R/D and barrier hoses at least) so you know you've got a system with integrity. Adding a kicker fan to the rear decklid condensor would probably help too. The new evap motor and switch can easily be done after you've dealt with the basic system (make sure you use screws to reassemble the evap box). If you find that it's still marginal you could then add a rear fender mounted condensor. I figured that trying to re-use anything 30+ years old was a false economy that I would regret and pay for again at a later point anyway, so that allowed me to throw out any budgetary constraints!! I prefer driving and playing golf to being a home mechanic so I wanted to do it once and get good results I'd be happy with. |
At least that's the way ALL modern day climate control systems operate in automatic mode, Lexus (NipponDenso), Ford, most US marques, (Denso US), and Porsche (Bosch) inclusive. |
So, where does one source a binary/trinary switch? And how would one put that switch in their system (is it an inline switch, or does it break off at a connector?)
WWest
Unless your car seals a lot better than mine, has tinted glass, a lot more/better insulation, more evaporator fan CFM, and an overall better sealed car...vent temps need to be quite cold and remain quite cold to keep occupants comfortable on a sunny, 100-degree day. Just because a modern car is in an "automatic" mode does not mean the vent temps are not very cold. Assuming a person does not build a different evaporator/fan and increase CFM to the vents, vent temp is the best measure of performance of system upgrades...as other variables remain constant other than ambient temp/humidity. |
TO r-mm........ Guy asks a fairly simple question as a newbie and all of a sudden it is a pissing contest over kuel and wwest. Perhaps we can help this guy without all the drama !!
1) The quickest way to cool down a hot car cabin, for example the cabin of the car that has been sitting in the 95F sun for 4 hours and has reached a typical interior of 120F+, is move that 120F+ air out quickly as possible. So, if it's 95F outside and you roll down all the windows and drive away, that would replace the 120F+ air with 95F air the quickest. There is no evap fan on this earth, lol, well maybe other than the Wirbelsturm which can exchange the air so quickly. 2) Assume you have 1000 cfm of 40F air vs. 100 cfm of 32F air, which will make the cockpit more comfortably .... quicker? Quote:
You're missing the point. If your car can't make cold air, then it's not a powerful system. If you want to measure an AC system's ability to make cold air, you measure the vent temp. After the car has cooled, it's up to you to make yourself comfortable - either by reducing the fan speed and keeping a cold temp, or raising the fan speed and going with a warmer temp.
If you have a giant fan pushing cool air, sure you could achieve the same results as cold air moving slower. But, we're all working with the same fan - so it's not a factor. Vent temp is going to determine whether you have a strong AC system or not. |
From another thread...this is what you are looking for:
This is what I'd love to see wwest post, but it seems it's either far too complicated, or far too embarrassing for him to do.
| All times are GMT -8. The time now is 08:02 AM. |
