| SilberUrS6 |
04-22-2013 09:25 PM |
Originally Posted by fintstone
(Post 7401879)
IAT does not change appreciably enough to make much difference...and is effectively OAT unless the vent temp is quite low and volume is quite high. If you start at 100F...a trickle of 65F air will not even overcome the engine heat and the sun coming through the windows. Most folks drive their 911s for an hour or two at most. The rate of change would never make a serious impact.
The max volume of air is fixed on all my 911s. It is on yours as well.
He's splitting hairs. The interior temp of the car is going to be much higher than the OAT, initially. 140-150 degrees F around here, in the summer. The big delta is opening the windows for a couple of minutes to get that super-heated air out, and to begin cooling all those IR-absorbing black materials in the car. All the while, the AC is running, and cooling the ductwork. Close up the car, turn the fan on high and let the Griff's evap fan blow hard on that higher-capacity evaporator. The interior temperature drops very nicely when the output air is 45 degrees at the highest air volume. Pretty soon, you have goosebumps and have to turn the air and the AC down a touch. The car is still at about 80 degrees, but the evaporative cooling on your skin is now in effect. And 80 is better than 140. Soon, the fan is at it's lowest speed, and the AC is set at the speed next to "off", and the air coming out of the vents is 35 degrees, and the interior temp is about 70, and steady.
