Best friend is my dog
When I grabbed the factory tool for the first time I thought it looked too big, too long and kind of crude. However, I quickly found that it is really a great tool for removing the plugs.
Old 09-11-2013, 06:40 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Originally Posted by James Brown View Post
your right, there wrong
For years I have used the same setup except instead of the swivel I use an added stubbie extension. Maybe 1 1/2 that matches the swivel length.
When I pull it out of the hole I have to pull the stubbie off to clear the engine sheet metal. With the swivel, I can see where you can just pull the wrench up to clear the sheet metal and no extra work is needed.
Thanks for the tip George!
1981 911SC Targa
Old 09-11-2013, 07:06 PM
Sounds good to me.I will make one as I am one of those blokes that bought a car WITHOUT a tool kit.Michael.
Old 09-12-2013, 11:10 PM
porsche0nut's Avatar
Originally Posted by Porchdog View Post
The plug wrench was missing from my tool kit...
LOL I never even thought to check my tool kit.... which is complete and lying right next to my toolbox!
Jonathan
'86 911 Coupe
Old 09-13-2013, 10:05 AM
AVIMAX's Avatar
The tool kit is very good, you can do many jobs without any additional tools. I removed the fan assay and alternator using only the tools that came with the car.
'86 Carrera Targa
'74 MGB
Old 09-13-2013, 10:18 AM
AutoBahned
RWebb's Avatar
Snap-Off makes some nice locking items that obviate the need for duct tape, welding, etc. etc.
Old 09-13-2013, 12:50 PM
Not as it seems
juanbenae's Avatar
Originally Posted by georgew123 View Post
Just to add to that tip... I put some electrical tape on the joint to firm it up a bit to help locate the socket onto the plug (removal) and locate the new plug (install) into the threads.
wow, great idea! not just for spark plugs, but elsewhere the floppy swivel has caused me heartburn. best nugget in this thread for this noob....
Old 09-13-2013, 12:56 PM
theiceman's Avatar
Well I just came home from a car show and picked up a 3 inch extension, a swivel and a spark plug socket for a buck each. I will now have a welded up permanent tool in my tool chest for 3 bucks.
I have the factory tool but this is way easier than breaking out the facttory tool kit. That is neatly bundled up in the front of the car.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 09-22-2013, 02:44 PM
Taking it apart is easy
Jerome74911S's Avatar
Originally Posted by redstack View Post
So you think that this $15 tool will be able to maneuver in the engine compartment?
The car I'm buying doesn't have the tool kit.
There's an Advance Auto Parts near me. I'm going to get one of those tools and forget about cobbled together arrangements, even if they do work. That tool is elegant. I have done plenty cussing with my poor DIY efforts, and this looks as if it will clean up my act.
Also, I've never even seen the factory tool, never mine own one.
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 09-22-2013, 03:02 PM
6 cylinder symphony
Another vote for the factory tool.
I like it so much, I bought an extra, so I don't have to open the trunk and dig around.
'84 3.2 Targa
'89 964 Coupe
"What do you mean NEXT project?" - my wife
Old 09-22-2013, 03:17 PM
Who here has actually changed the plugs more than once ?
Old 09-22-2013, 05:53 PM
BlkBird's Avatar
My factory spark plug doesn't fit my aftermarket plugs. Joys of having super duper Turbo plugs. And that cursed inter cooler needs to come out and... All afternoon job for me I suspect.
C.H.
Boost Addiction - honestly, I have it under control
1989 911 Turbo Cabriolet
Mods include: Kokeln IC, GHL Headers, Hooligan muffler, Modified K27 7200, BL WUR, LC-1 & XD-16, Bilstein Sports (4), TRG sway bars, Oversize torsion bars, Strut brace
Old 09-22-2013, 06:27 PM
theiceman's Avatar
Huh? I replace them every two years religiously.. And I only drive summers..
Old 09-22-2013, 06:30 PM
Reiver
Reiver's Avatar
Every year at valve adjust time.
Old 09-23-2013, 12:24 PM
theiceman's Avatar
Well i just scored a major bonus ... the used extension and swivel i bought must have been outside for a while so the tiny ball and spring were completely seized.. had to hammer the bastard thing together .... no welder needed
Old 09-23-2013, 12:40 PM
Hell Belcho
Nostril Cheese's Avatar
This is what I use. Snap-on 13/16th's swivel spark plug tool. It has a magnetic insert that holds the plug so that you dont get it stuck on the plug down in the valve cover.
Old 09-23-2013, 01:54 PM
Is this necessary? Plugs go 100k miles on modern cars.
Is this b/c of the modern plugs, or b/c of the modern ignition systems?
Old 09-23-2013, 04:27 PM
AutoBahned
RWebb's Avatar
both - also, modern fuel mgmt systems
Old 09-23-2013, 05:06 PM
4SFED's Avatar
Have a very similar setup with electrical tape and it works flawlessly on 4 cyls.... #1 and #6 are darn-near impossible. I still can't get to #6....
Jake
1973 Tangerine 911S
1967 Corvette Roadster - Triple Black
Old 10-27-2013, 06:26 PM
redstrosekNic's Avatar
Weird. Do you have a pic of your set up? I have no issues with any plugs using my combo.
Dustin
Old 10-27-2013, 08:11 PM
