dizzy shaft parts order
I've examined all of the diagrams I could find on the web. Does this look about right? The gold oil lite washer near the bottom replaces a fiber washer that broke apart. The new one is quite a bit thicker. I think the bottom is good.
The three items on the left side of the picture, lined up horizontally beneath the pick, are leftovers. I thought they went up top, but they don't fit over the top end of the shaft. It's certainly possible they were used as spacers on the bottom. I guess I'll figure that out when I measure the clearance. It's the top I'm concerned about now...
1983 SC
Blog
Old 04-23-2013, 12:32 AM
this has some useful info
Jason
81 SC
97 328is
87 Jeep Comanche (RIP)
Old 04-23-2013, 01:02 AM
Yes, I have that. (Thanks again for emailing me the PDF!) No mention of washers up top in this document. Could ne a clue. Then again, no mention of snap rings either, and I know there are two of those...
Old 04-23-2013, 09:36 AM
Arrow
One or more thin washers go above the advance plate up top.
DIY -- Distributor Vacuum Pod Delete and Vacuum Lockout
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 04-23-2013, 09:47 AM
I think the fiber washer and a shim may go between the housing and the advance plate i.e., beneath the advance plate. It spins better like this...
Old 04-23-2013, 03:33 PM
Just make sure the pig tail connector lines up with the hole in the housing.
Old 04-23-2013, 05:44 PM
