Steering wheel squeak
have developed a severe steering wheel squeak over the past 6-8 weeks.
This is a light but grating squeak from the wheel itself as it turns, do not believe that it has anything to do with the steering column. I have no upwards or sideways movement should I pull on the wheel. Have taken the wheel off and lubed twice, ok for a little while, then comes right back. Any insight appreciated, it is driving me nuts! Regards, Glen
Glen 78SC(D) EFI Targa |
Mo money = mo parts
What are you lubing? Also, factory wheel/hub?
Greg 86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten 65 Ducati Monza 250 & 66 Monza Junior (project) "if you are lucky enough to own a Porsche, you are lucky enough" |
Go-Kart Mozart
It's the horn contact ring and column contact wearing in. The ring wears a groove in the contact. Then the plastic edges of the ring rub against the contact and make the grating sound. One fix is to sand down the plastic edges to minimize contact. I tried filling in the groove in the contact with solder but that only lasted 3 to 4 months. The contact is NLA from anyone but Zims. They have an a/m version that works well and is cheap. -J
Member 911 Anonymous
need to service mine for the summer
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Thanks guys, I have an all original setup.
The horn contact has a nice groove worn into (and through) it, I bent the contact so that the groove wasn't in contact with the wheel - basically made the hump a little further along its length, so had discounted this as a cause. The noise definitely sounds like plastic on plastic or light metal. I'll revisit the contacts again, many thanks
