Should the A/C temperature switch click into each notch or spin freely?
I was contemplating an A/C overhaul with the retroair system, but began playing around with the knobs in the center console in my 89'. I was wondering whether or not the temperature switch should click at each white mark (like the fan speed switch clicks at level 1 level 2 level 3) or should it spin freely between low and high?
Old 04-07-2013, 08:05 PM
Go-Kart Mozart
JAR0023's Avatar
Mine spins freely in my '86. -J
Old 04-07-2013, 08:59 PM
kuehl's Avatar
The thermostat (LH knob) does not click at each white hash mark. The marks on the bezel are just a reference point. However, many times you can feel or hear a light 'click' when you turn the switch completely off... CCW.
And, when the system is operating, if things are real quite in the cab you can hear the thermostat contacts make and break to turn the compressor on and off.
The fan speed switch (RH knob) does have 3 'clicks' forward from the 12 o'clock off position, from CCW to CW: off, 1, 2, 3 speeds
The Mr. Ice Project
Last edited by kuehl; 04-25-2013 at 03:20 PM.. Reason: for benefit of those whom listen
Old 04-08-2013, 05:40 AM
wwest's Avatar
The temperature control is simply acting against a "tension" spring thereby adusting the level of pressure required inside the capillary tube that it will take to close the electrical contacts and (re)start the compressor.
Old 04-08-2013, 09:48 AM
kuehl's Avatar
lol
AC Help
Old 04-08-2013, 10:40 AM
wwest's Avatar
Originally Posted by kuehl View Post
"Spring"/Bellows, Bellows will remain "springy" even when fully evacuated.
Be carefull, that link contains a few bits of incorrect info.
Thermostatic switch calibration setting, and sight glass use, examination, for instance.
Old 04-25-2013, 10:52 AM
kuehl's Avatar
lol, "you" can't adjust the "level of pressure inside the cap tube".
Old 04-25-2013, 11:06 AM
wwest's Avatar
Sorry, but I don't remember at this moment just how the calibration screw "acts" on/against the spring/bellows but clearly, it does, CAN. My guess would be that there is some arrangment for "adjusting" the "latent" spring tension of the bellows.
Old 04-25-2013, 12:12 PM
kuehl's Avatar
Oh. Are you having a Senior Moment?
Old 04-25-2013, 12:48 PM
Banned
Ummm, aren't ALL of his moments "senior" moments?
Old 04-25-2013, 02:24 PM
wwest's Avatar
Yes.
Old 04-25-2013, 03:13 PM
kuehl's Avatar
The end!
Old 04-25-2013, 03:20 PM
wwest's Avatar
Oh, I finally got it..!!
Undoubtedly yet another senor moment.
YOU mis-read my statement. To clarify...
The screw allows one to adjust which/what level of pressure, (lack of, actually) inside the spring/bellows that will be required to open the switch.
Old 04-25-2013, 06:11 PM
