Spark Plug Change Done
OK, I feel like I just won a minor battle so here are my notes from my first spark plug change:
1) if you have a factory toolkit make sure your spark plug wrench is the right size (apparently at some point mine got changed out and it is too small!). 2) in lieu of a factory plug wrench , you can use a standard plug socket with a 3 inch adapter and a universal joint. 3) make sure you use either duck tape or filament tape to tape the plug socket to the adapter (if you don't there is a very good chance the adapter will detach from the socket when you go to pull it out ... ask me how I know and how your innerds tighten up when you realize the socket is still in the hole). 4) even with moving the AC compressor #6 is still a PITA to get to so it helps to have long narrow arms. All in all this was a relatively simple DIY project and with the right tools and some patience everyone should be able to do this. For my first time it took just over 1 hour everything included. Once you know what you are doing I think this could easily be done in 30 or 40 minutes max. BTW, all 6 of my plugs were evenly worn with a very light white coating on the plug end. Interestingly though the previous plugs were Bosch platinums (WR5DP) but the gap was between .023 and .024 on all 6. I put in regular Bosch (W5DC) and gapped them to .030. It will be interesting to see how she runs with new plugs. Happy motoring!
Doug '81 SC Coupe |
You're right! The # 6 plug is a bugger so I usually start with it. I know the back of my hands are gonna be bruised because of the mount that is just above it. Just can't figure out a way to get enough leverage to work in that confined space without my hands getting beat up by that damn mount..has sharp corner and juts out above plug hole!
Howie 79SC |
