911 mpg
Is it possible for a 1974 911 to get 34 mpg? Just took a trip to New Hampshire, 340 miles round trip. Filled up before we left, gauge reads 1/2 tank upon return. Drove very conservatively around 3200 rpm on the highway and most of the trip was highway miles. I assume the gas gauge may be incorrect Any thoughts?
Old 06-27-2011, 07:31 AM
76 911S Targa
Fill it up at the pump and let us know what your mileage was on this trip. I am curious. My 76 has been getting around 24 on long steady drives.
Old 06-27-2011, 07:35 AM
34 would be pretty impressive. I have seen high 20s when I was stuck driving at 60 to 65 for long trips. On the track I have seen single digit MPG.
just me
paulgtr's Avatar
Send a message via Yahoo to paulgtr
34 seems high. I have averaged 25 for a highway trip. but I was doing 70-80.
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses.
http://www.hairydoggrrrage.com/
Old 06-27-2011, 07:37 AM
gwmac's Avatar
My 74 2.7 CIS gets about 16.
Old 06-27-2011, 07:46 AM
r_towle's Avatar
use a gps to check your real speed and verify it against your speedometer.
Tire size may change your speedo (and odometer) up to 10%.
Rich
Old 06-27-2011, 07:47 AM
Retired Member
Charlie V's Avatar
A couple weekends back we did a 1800 kms trip on the back highways. A faily spirited drive netted 25.8 mpg for imperial gallons. That works out to 20.6 for US gallon.
1982 911 SC Targa - Rosie....my Mistress. Rosewood Metallic on Dark Brown and Black. Long distance road warrior and canyon carver. A few mods - a little interior, some brakes, most suspension and all of the engine.
Old 06-27-2011, 07:53 AM
Spiderman
Jesse16's Avatar
I've gotten over 30 mpg driving between 45 and 55 mph through the country on windy roads, cool weather, and the windows down. Mine is a 87 Carrera. Probably couldn't have had better mpg conditions. Otherwise, highway mileage is a pretty steady 25 or 26 at around 70 mph on long trips. Just drove 2500 miles going from NC to NY state to Watkins Glen and back.
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 06-27-2011, 07:54 AM
Boricua21's Avatar
I get 20-21 on my 3.2 powered SC...50-50 rural/city...I'm sure I can get 3-4 more on the highway...
Arnie Diaz
Braselton, GA
1982 911 SC (3.2), Fabspeed Bypass and Muffler
2003 E39 BMW 530i (Daily Driver)
Old 06-27-2011, 08:09 AM
Just this weekend I squeezed 25 mpg out of my 3.6 75 targa. Usually I get around 19. I was cruising at about 3000 rpms in 5th the whole trip when I got the 25mpgs
Old 06-27-2011, 08:47 AM
SC Ray
81 SC Ray's Avatar
No way - unless you went downhill the whole way...... :-)
Old 06-27-2011, 09:09 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Air Filter effects mileage too.
I swapped back to the OEM paper filter and modified the air box cover. I do notice a considerbale drop in mileage per tank.
But cleaner oil is better for her anyways.
34 MPG, Wow that is quite good, almost too good to be true.
+1, Fill then divide mileage, filling will also approximate if the gauge is calibrated/reading properly. But you knew this
'85 Carrera Targa
PCA/POC
Old 06-27-2011, 09:13 AM
Paper Member
The best I could ever do in my SC is about 25 mpg.
Enemy of the State
Brandolini’s Law: It takes hours more time, research, and writing to debunk misinformation than it takes to spread it.
Old 06-27-2011, 09:15 AM
Most mpg that I ever got in a Porsche was a 68 912, rebuilt motor (1974) on a trip to Florida from DC going around 3400rpm (75-80mph) the whole way, 34 mpg. My 70T averages around 25 around town and the 3.2 is around 23. 34 in a 911 would be most impressive. Steve
1970 911T SOLD
1989 3.2 Carrera
2013 991 Carrera S
Old 06-27-2011, 11:51 AM
I have a '74, I just had the gas gauge on the dash fixed it would read 1/2 tank when it should read "R". Before fixing I always fill up after 300 miles. Combo city / highway the best I get is 19mpg.
Old 06-27-2011, 12:03 PM
BruceC's Avatar
Half on the guage is not necessarily half the tank. You have to fill up again, note the number of gallons it took to fill up, then do the math!
Bruce
www.bcaudio.com
1995 Metallic Black 993 Coupe
DACH Sport Cats | Euro Sport Suspension | 18" Hollow Turbo Twists | Motorsound Airbox | Engine Tray Delete
Old 06-27-2011, 12:13 PM
Back in the dark days of a the national 55 MPH speed limit I drove my 914 2.0 on a trip. The cops were thick so I drove 55 and got 36 MPG. I don't think my 911 could get 34 even at 55 MPH.
Old 06-27-2011, 12:21 PM
lupin..the..3rd's Avatar
Send a message via AIM to lupin..the..3rd
a 36 year old fuel gauge and sender is a poor way to calculate fuel economy.
fill your tank at the pump to determine how much has been consumed on your trip.
SOLD: '87 Carrera
Old 06-27-2011, 12:27 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
If you are after better fuel milage with any car, not just our 911's...then you need to address the whole problem.
Tire pressure...tire size (narrower for better mileage)..brake type (disc pads drag on the rotor)...fuel...weight of foot on throttle (LOL)...and type of terrain (hills bad...flat good).
Carbs or injection can contribute.
Injection system with feedback on both fuel and ignition would be good.
With carbs...the problem is the enrichment system..avery time you wiggle your toes, the gas mileage goes down.
The old SU carbs were good...no accel pumps.
BUT...and this is a big "but"...the car will no longer be a 911..at least not the 911 you want.
For extreme gas mileage...try an old 3 cyl Fiat...they used to get over 80 MPG...but at the price of being a total stone!
Bob
Bob Hutson
Old 06-27-2011, 01:34 PM
If your referring to me, I'm not kidding. Best I've gotten ever. Filled her up with just shy of 12 gallons at 300 miles. Included driving through grants pass. Was heading north on i5 from medford Oregon. I have 315/35/17's in the rear. I was pretty surprised my self. My 914 got about 37 mpg to portland once but has dropped significantly since going to 205/50/15's
Old 06-27-2011, 02:52 PM
