You can do one more check to see if the DME computer (ECM) is getting power at terminals 18 and 35. If it is getting power, then ECM is suspect.
1993 964 C2 still makes me smile Retired and work as needed as a pain in the **s. |
87 Carerra, 3.2 liter en
I will do the test on the power to the ECM tomorrow. But I am just curious. I know I am having problems with the injectors not spraying. Perhaps that is the ECM injector board. But I tested the ECM at prongs 1&19 and got a pulsation to the coil. So, even if I am having problems with the ECM, it appears to be putting out a pulse to the coil. My problem is that the coil is not reading the pulse from the ECM signal and distributing it to the distributor for a spark. Could fault from the ECM come into play under that scenario |
From what I've read, you didn't drop the engine. ? There is a pin on the flywheel the the sensors need. Just a thought, read this thread. Sorta sounds like your problem. 86 won't start after new flywheel? no injector or coil pulse.
As well, there exists some resistance measurements/specs within the Bentley that will give you a static resistive read of both primary and secondary coil condition. Of course, sometimes, when heat is expended, things change: still, a good check. Best! Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
The ground is was referring to at the battery is the neg. battery cable. It is grounded to the right. Of the battery. Pull battery out and you will see it.
I have questions highlighted in green. Can you answer them pls.?
Bazaar:
In answering two your two specific questions. 1. No i did not disconnect the ECM (brain on the inside of the car) from the ECM harness when i checked the ground on each left injector prong. 2. When I checked pins 1 & 19 I used a voltage meter. the mechanic who was reading the meter said it was pulsing. I did not see it, and I really do not know if he knew how to actually read the meter. I simply went off of his word. Could you share with me your suspicions that prompted your questions because i am truly stumped |
2. It is really hard to see the pulsing on a digital meter display. A scope meter will be best. With your test, you really cannot say the ECM is providing the ground pulse to the ignition coil. The ignition coil pulse signal is a series of fast 12V and 0V switching signal. 12V saturates the ignition coil primary coil and zero volt causes a collapse in EMF on the primary coil to induce the high voltage spark on the secondary high voltage coil. The high voltage gives the spark plug the high voltage arcing. Are you going to send out your ECM for testng? You can just wait until you get the ECM back to confirm your ECM is good, then troubleshoot further.
I am going to send out the Brain now. I will get it back and then troubleshoot from there. Thanks so much for you and everyone else's patience and guidance. |
Here are the diagrams for the fuel injectors and spark ignition. This will help. Injectors: ![]() Ignition: ![]() Let me know if you need the complete file in pdf.
Just to give a little information on the coil, the black wire is a 12V source when the key is in the run or start position to the coil +15 terminal. The green wire goes from the coil '-' connection back to the DME, which makes the connection to one of the brown ground wires connected to the intake runner to trigger the spark. There is no signal on the green wire, just a series of intermittant ground connections to trigger the spark. It works like a set of electronic points opening and closing the ground connection.
Ed 1973.5 T |
The DME ignition driver circuit provides the grounding to achieve the zero volt pulse. The grounding is internal to the DME circuitry. The DME itself which is located inside the cabin has it's own grounding point and does not need the grounding point in the intake runner.
Srwilliams, I hope this doesn't confuse you.
I realize this is somewhat off track, but I enjoy learning from others also. I respectfully will agree with you, you are the Engineer and I am the Electrician. I have not had the training in electronics you have and over simplified the ground connection. While not a direct connection, it just seems to me that internal grounds seem to come from the external ground wires on the intake runner. Most of the ground connections seem common from what I can make out of the diagram, aside from the bridge connection for the California emissions ground. ![]() Also, a note on the coil from the manual for Srwilliams. Testing of the coil should not be with leads on the meter across the coil (+)15 and(-). They also seem concerned with how the terminations are made on the coil.
Ed 1973.5 T |
Sully:
No problem. I am in the background smiling as I pick up little tidbits of scrape information that falls to the side during the exchanges of two heavyweights---Bazar and Sully. In truth, I am learning a lot from the debates and meetings of the minds that the two of you come to. Also, it lets all of the rest of us neophites and DIY people know the level of knowledge we need to reach to be able to effectively work on our cars. I am so impressed by the knowledge that people like Bazar and Sully have, as well as their ability to break matters down on the base level so people on my level can understand. they never once have talked over my head in trying to assist me |
Spoke with a VERY knowing Porsche guy today and he was quite concerned (with all of the disconnects) that the sensor connections didn't get swapped on the reconnect, as this would give you the indications you are experiencing. Hopefully, you've already put that suggestion to bed.
Best! Doyle
Hey y'all, i take no offense in constructive disagreements. I just wanted to make sure the information on this thread is correct and will be useful to anybody down the road.
This board is all about helping and learning from each other. We all love to work on our pcars.
Doyle: Both me and a knowledgeable porsche enthusiast covered the sensor possibility (mis-swap) several times. In fact that is the first troubleshooting we did. But I really want to thank you for the level of your concern of my predicament that you consulted with your own resources. For you to go to that extent to assist me really speaks to your level of concern and consideration. Thanks so much |
My apologies, SRWilliams. I've just now read the entire thread and obviously missed your reference,...so, onward (with the sensors having already been checked).
Best, Doyle
ASE Master Tech - 35 yrs
was this O.P. ever solved?
![]() - a report would be useful, in any case, i am posting this possible solution so that a future comrade who stumbles here via google will have a decent clue about a possible solution i had a similar problem as of 3 days ago; (5 days before that i drove it over 600 miles with no problems) '89 3.2 ... suddenly just began running like on half cyls after a mile (like fuel starvation, then would pick up momentarily, .... then died completely & no start - i went thru testing most of the "usual" suspects starting with the DME Relay; then the Test Plan ( the Relay is good - the pump works per spec ign on & crank, , it has good spark, no NOID indication, swapped DME/ECU, etc); it does start & run on starting fluid; - starting on the circuit tests suggested in this thread, & my enlarged factory wiring diagrams in hand, i discovered no 12V at the injectors, and no continuity from Pin 87 of the DME Relay socket to the injectors - so i apparently had an open in the harness today, i discovered that the injector harness 6-pole plug had simply come undone - it just vibrated loose ![]() (to paraphrase rusnak "that is weird") - obviously had to be working its way loose for a long while - (spirited driving on rough mountain roads a possible contributor, but the wiring loom was securely bolted to the manifiold per oem just 2" or so from the plug )p.s. - this thread has lot's of good troubleshooting info i've not seen in many others O.P. QUOTE=Srwilliams;7427450] in fault checking my no-start issue I have traced it down to my injectors not spraying.
"... I am German, and if it has no logic it's meaningless." 914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
solved - see above edited post
