wiring question 70 t/ front lid seal
I am closing in on my final reconnection issues on a 70t. Below are some pictures that I need some help with.
1. Behind the dash at the rear winshield heater switch there is an open male connector and behind the blower i found 2 wires connected that show on the SL35 wiring diagram a note that says Nebelschlusslicht (SW). White w/ black and white w/ green. Do these connect on to the heater switch?
2. Which location does the front hood seal belong. ? Top or bottom photo.
Old 05-08-2013, 07:34 AM
E Sully's Avatar
White/Green should be optional rear foglight.
White/Black is probably for 2 stage rear window defroster. Single stage only used the Black wire.
Trunk seal is upper, lower is front bumper to body seal.
Ed
1973.5 T
Old 05-08-2013, 09:49 AM
I was mistaken the open connector is on the cigarette lighter. Do these wires need to be connected?
Old 05-08-2013, 08:17 PM
E Sully's Avatar
I want to avoid confusion here. Do you have the optional webasto gas heater, and do you have a single or 2 stage rear window defroster? Any other options like front or rear fog lights or rear windshield wiper?
Ed
1973.5 T
Old 05-09-2013, 12:26 PM
My rear window has red with white wire and brown ground. I have not used so I do not know if single or two stage. How do you know? Also no fog lights or special heater.
Old 05-11-2013, 07:44 AM
E Sully's Avatar
It sounds like you have a single stage. The defroster switch will only have one position. The W/Bk will be spare. With 2 stage there would be R/W R/Bk and Br going to the rear window.
In this picture of the rear electrical console, you will only have the black relay #2 if it is single stage. If you have item #6 the rectangular relay then it is 2 stage.
I am going to check a few things to check the W/Gr wire.
Ed
1973.5 T
Old 05-11-2013, 09:09 AM
E Sully's Avatar
As near as I can tell without being able to physically check myself, the W/Bk should be a spare for 2 stage defroster. The W/Gr should be a spare for the optional rear fog light. You can verify it by checking continuity to the spare wires bundled by the drivers rear tail light, shown in the picture.
Ed
1973.5 T
Old 05-11-2013, 12:37 PM
