1974 911 w/ 83 SC engine
Does anyone else's SC pop this much on decel?
I have an '83 SC engine (w/ P's and C's bumped out to 3.2L) in a '74 chassis. Flowmaster muffler. Normal CIS. No cat. Normal heat exchangers.
Every time I lift off the throttle at anything over 3k, I get a backrap that almost sounds like a machine gun. Just a rapid series of pops and crackles. If I take it out of gear, it doesn't do it. Does anyone else's car pop this much on throttle lift-off? It might be hard to hear, but listen as it bounces off the wall of the exit ramp.
http://www.youtube.com/watch?v=VS9Y4mj39Bs
Old 05-06-2013, 07:41 PM
ROW '78 911 Targa
timmy2's Avatar
Yes... Sounds great!
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 05-06-2013, 08:01 PM
Senior Advisor
James Brown's Avatar
combination of several factors, negative torque (car driving engine instead of engine driving car), CIS, and the flowmaster. You paid for it, enjoy!!!!
08 Cayenne Turbo
Old 05-06-2013, 08:17 PM
RETIRED
Joe Bob's Avatar
"Usually" backfire and popping on decel is an an exhaust leak.
2012 ML350 3.0 Turbo Diesel
Old 05-06-2013, 08:18 PM
if your deceleration valve is unplugged it will do that .
Old 05-06-2013, 08:20 PM
I don't know if my decel valve is unplugged, but if I'm not doing any damage then I'm going to leave it as is. I love the sound but a little concerned is was TOO much and something was wrong. Thanks guys.
Old 05-06-2013, 08:25 PM
scarceller's Avatar
If you have any sort of open exhaust you will hear this on decel. Reason for this is that on decel the CIS cars still fuel the engine slightly and under this very high vacuum scenario you have very small amount of air fuel mixture entering the cyl. Here the flame front speed is significantly reduced and requires tons of extra ignition timing to compensate for the slow flame front speed but the CIS cars don't have programmable ignition timing so the spark plug fires a bit to late for the given condition, the end result is that air/fuel is still burning when the exhaust valve opens.
I know this issue well as I have removed this exact problem area from my 84 Carrera by adding tons of ignition timing at very low (decel) loads. I run SSIs into a 2in2out MK pipe and my car did this terribly till I altered the ignition in the DME.
With a CIS engine you just live with it or put back a quieter exhaust.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 05-07-2013, 05:31 AM
schumicat's Avatar
even with my decel valve plugged (while doing some troubleshooting) mine didn't pop nearly that much.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 05-07-2013, 06:17 AM
kjchristopher's Avatar
In this spirit, the popping lessens if you don't have the vacuum retard connected on the distributor.
Old 05-07-2013, 06:20 AM
Eva
911SauCy's Avatar
Mine does the same thing, condition lessens quite a bit when the car is "hot".
My situation also includes no cat, a "muffler-delete" and a plugged decel valve...
GOD I LOVE THAT SOUND!
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 05-07-2013, 07:04 AM
scarceller's Avatar
Worth noting is that many modern day EFI systems allow for shutting down fuel and the better ones even provide shutting down both fuel and ignition during decel.
Some engines can become very annoying with excessive popping but I tend to agree some popping can sound real nice.
Sal
1964 356SC (SOLD)
Old 05-07-2013, 07:31 AM
you see Arthur...
jasonlee's Avatar
my does that, and I really like it, running a cat bypass, and flow master muffler. Enjoy it.
J
82 911 SC, Cat bypass, Flowmaster 1 in 2 out lightweight flywheel and backdated heat
06 Cayenne S
00 ML 55 AMG
Santa Cruz Bullit
Old 05-07-2013, 07:32 AM
tazzieman's Avatar
Since installing SSIs and a Monty muffler I've noticed the popping , quite nice really and in keeping with backdating ! As I drive down 2 long steep hills each morning , it is part of the dawn chorus now.
'81 924 , '85 944 , '78 911SC , '82 928 5.0L
"They run best being run close to the ‘limit’ and done so regularly" - Grady
Old 05-07-2013, 03:15 PM
LOL. That's not really a problem, sounds nice... CIS 930's pop, bang, burble. cackle and backfire more than that factory stock - including flameballs if the turbo is hot enough to ignite the fuel that's causing it.
If you don't like it (or want to avoid the attention), try holding the throttle plate a fraction off the stop on the overrun (e.g. don't just take your foot completely out of throttle)
'77 S with '78 930 power and a few other things.
Old 05-07-2013, 09:57 PM
Gordo2's Avatar
Burble
My 83 SC is more pronounced (worse, better?). Two known causes for my exhaust rumble and pop on loaded decelleration:
#1. I disconnected & plugged the vacuum line for the deceleration valve years ago - it wasn't working and was causing the idle to intermittently hang at ~ 1300 RPM. this alone caused some burbling with the stock exhaust.
#2. I installed a cat bypass pipe and modified 1 in - 2 out muffler. The flange that mates the cat pipe to the muffler is warped and leaks. Last fall I replaced the gasket and was able to get a leak free connection. The popping and burbling nearly disappeared (back to levels associated with decel valve). Since then the gasket has blown out again and I'm back to the full on rumble.
Gordo
Don "Gordo" Gordon
'83 911SC Targa
Old 05-08-2013, 04:15 PM
