Guest
Posts: n/a
how do i change front break pads on a 2003 porsche 911, thanks in advance
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Replacing the Air Filter - 911 (1965-89) - 930 Turbo (1975-89) |
You have to remove the brake pade spring clip retaining pin. It has a cotter pin holding it in, then drive the pinout. Once out, remove the spring. Then lever the brake pads off the brake pad damper. Then remove the pads. Assemble the parts in the reverse order you took them apart. You can also call our parts specialists and grab a repair manual for your vehicle: 1-888-280-7799
- Nick |
