Bird. It's the word...
Fishcop's Avatar
Problems with Front Camber
After recently upgrading all my suspension bushing with weltmeister, I took the car in today for a 4 wheel alignment.
I gave them my prefered settings (Rear -1.8 and Front -1.0), however they could not do any better than L -2.28 R -1.76 What would be causing the lack of adjustment?
A camber brace has been a suggested addition to help push on the towers? Good idea?
Input welcome
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 07-17-2002, 10:15 PM
You shouldn't have to be 'pushing' anything. Sounds like something is bent.
Old 07-17-2002, 10:19 PM
Fishcop's Avatar
Hmmm, that's what I was afraid of. The rear adjusted perfectly, but they complained of "a lack of adjustability" on the front.
Cheers
John Forcier
Old 07-17-2002, 10:27 PM
Chuck Moreland's Avatar
John
Is your car lowered? That can cause this problem.
You can do some grinding to the hole at the top of the shock tower to pick up a little more range.
Chuck Moreland - elephantracing.com - vonnen.com
Old 07-17-2002, 11:02 PM
Fishcop's Avatar
Okay, that would explain quite a bit!
I lowered the car by about 1" when I did the front A arms. So a combination of lifting the front a little and reaming the hole will probably fix it?
Thanks Chuck, your advice is invaluable
John Forcier
Old 07-17-2002, 11:08 PM
John,
Ream here:
I took out about 3/16 inch and gained and extra degree of range.
Your rear sounds like it's fine. But you can gain range by grinding the spring plate too. Or you can fit a smaller bolt to give more range.
Good luck.
Old 07-18-2002, 08:47 AM
I've seen this before. It was caused by a cracked weld where the strut tube inserts into the spindle. They just tack weld those parts and a good pot hole or curb hit will bust that weld. Might want to check that out prior to grinding. It's the kind of thing that you might not notice unless you look for it.
1973 911T Sepia Brown MFI
1986 Carrera Meteor Gray Metallic
Old 07-18-2002, 09:23 AM
KTL KTL is online now
Schleprock
KTL's Avatar
John,
Go to this thread and read the second scanned picture I posted. Towards the bottom in Tech. Tip One, it says that some 911's are hard to get neg. camber, blah blah blah. I'm not saying this Weltmeister info. is gospel, just saying that it's not necessarily something wrong with your car.
Cambermeister Instructions
Kevin L
'86 Carrera "Larry"
Old 07-18-2002, 11:53 AM
Irrationally exuberant
ChrisBennet's Avatar
A lot of 911 guys would love to get that much camber for the track. Kumho's want 2-3 degrees of negative camber for example.
-Chris
Old 07-18-2002, 12:12 PM
Had the same problem. Bought a set of ERP monoball top shock mounts, and that afforded some more (i.e. less negative camber) adjustment range, plus I also reamed away a little of the metal as was suggested above.
STephan
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 07-18-2002, 03:05 PM
Fishcop's Avatar
Thanks! Great stuff from everybody.
One day I'll have a weekend where all I do is drive my car
Now where is that die-grinder.......
John Forcier
Old 07-18-2002, 04:02 PM
