Seat not centered with Steering Wheel
Well, I installed a seat of seats in my car last night (it has been under the knife for 2 years now) and I noticed that the seats are not centered with the steering wheel. I asked a buddy of mine and he mentioned that this has always been a problem with 911's and that the seats won't go over enough to completely fix it. Has anyone tackled this issue? Can is see some of your solutions?
-Britain
'69 912 w/ 2.3L Type-4 Turbo Engine '74 914 1825lbs, JDM Subaru STi Spec-C Engine, Lotus Suspension, 930 Trans. '80 924 AAN 5-Cyl, Corvette C5 Transaxle - Team UBoot Rennwerks -- www.britainracing.com -- |
Banned
The design is like that,all off them are the same.,chhers,Antonio.
I am sure that someone has done something to get it closer.
-Britain
Me like track days
I'd be interested. Canted to the left, very odd feeling.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
Isn't the 930 steering wheel off-center to put it on-center in relation to the seat? You could always switch wheels if it is.
-Sam
Sam Gonzales '69 912 2.0 -6 power |
Hey Britain,
I do remember reading about a Pelican who installed some new seats and fabbed his brackets to compensate. Only a slight "shift" in the position, but he was happy. Sorry I don't remember the details, but it's in the archives somewhere ![]() -Chris
1987 Guards Red Targa (sold) 2006 Toyota Tundra DC 4x4, the "man-e-van" 1998 CR500 Well on the fringe...... |
The seats are centered. Its the controls that are off center!
Dave |
My one piece race buckets are perfectly centered with the steering wheel. This involved cutting our the whole stock mount assembly and welding in a custom set up.....
Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Any pictures of those modifications.
-Britain
Camera on the fritz, but what I did was to weld in some box section pieces across the floor between the rocker and the tunnel, one at the front and one at the back. Then I welded some angle iron to it to form longitudinals that the new sliders mount too. The front cross piece is taller than the rear one to aid in seat inclination. It was pretty simple to do, but I am sure there are more imaginative setups out there. I went this way becuase I did not want to get my welder working on the tunnel where the fuel lines are-heard too many stories about that! Otherwise I would have just welded longitudinals against the rocker and the tunnel much like the factory did and then centered the seat on it. Of course this is much easier with a seat that is more narrow than a stock one.
Cheers,
Banned
I hear, long time ago, that the steering not been centered revolved around a safety issue. So this is within the design parameters of the car.Cheers,Antonio.
I have the same feeling. The first impression when I bought my 911 was that I feel like I am facing a little to the right (toward the middle of the car), when I drive.
Fat butt 911, 1987 |
Just part of the charm
i noticed it more when its parked and you look thru the windshield .. from inside it feels right ... but different from any other .. gives it charm ...
Once got asked if the car was wrecked and crabbed down the road ... |
Air Medal or two
late 60s most manufacturers placed the steering wheel off to one side for crash protection
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
RETIRED
Get used to it.....it's like a women....they ain't all centered.....trust me.
Red ones be the worst....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
I made a custom bracket for our Recaro SPG seat moving it about an 1" to line up with the center of the steering wheel (and the pedals). When your sitting in a tight race seat it makes a difference.
Harold '79 930/DP935 (sold) '68 VW 3.3 Turbo Crewcab |
The 914 is weirder, ....surprised? The steering wheel is tilted slightly to the left as if someone out side the car might want to steer it awhile...
Once you are driving though it all seems to come together wonderfully.
jt '83 SC '96 M3 6 Bicycles 2 Sailboats |
Wasn't the old WV beetle steering wheel also off center with the driver's seat? I thought I remember that.
79 SC Targa 72 T Targa Sold 68 T Coupe Sold 65 912 Coupe Sold 62 356B Coupe Sold |
Dragging up an old thread. I just put "new to me" Boxster seats back in my car after 3 years of having the interior gutted and got reminded of the same issue. Steering wheel appears shifted off-center (toward the middle of the car) by ~40mm. Is this somewhat normal?
