View Poll Results: 911SC Engine - Repair or Upgrade
Repair current engine, return to stock 30 61.22%
Replace current engine with 3.2 19 38.78%
Repair current engine, leave as-is and sell 0 0%
Voters: 49. This poll is closed
Slippery Slope Expert
Steam Driver's Avatar
911SC Engine - What to do?
I have a 911SC engine that I'm in a quandary about what to do with. This is in my barnfind car that (in addition to it's other issues) hasn't run for about 10 -15 years.
It turns out that it is VERY much played with from the P/O's being an avid autocrosser back in the day. In addition to the exhaust issues (early heat exchangers, factory sport muffler, no cat) it has been backdated to '78-'79 specs otherwise; large port heads, large intake runners, no K-jetronic wiring harness (although I have that in hand now); and with a Euro ROW distributor (no vacuum advance/retard). I understand this was a popular thing to do back then. (Maybe still if one doesn't have to deal with the Draconian emissions law we have here in Hamilton County, TN) In addition it ALSO has a broken head stud.
So the questio is, do I repair the head stud and attempt to run down the parts to return it to '82 stock, or just say to hell with it, sell the engine as a core, and upgrade to a 3.2?
Old 06-11-2013, 04:48 AM
non-whiner
mreid's Avatar
For the hassle and cost, you could update your current 3.0 to 3.2 specs and have a known entity.
"Too much is just enough."
Old 06-11-2013, 04:50 AM
Well that's an idea I hadn't though of. I assume you mean run down the 3.2 intake system and ECU, etc. as well. Might it not be more cost-effective to sell this engine as is and get a 3.2 with all it's accessories? But you're right about the known entity.
Old 06-11-2013, 05:01 AM
Recreational Mechanic
Nickshu's Avatar
No personal experience but all the harness swap out for a 3.2 would be more work than the engine swap. Others have done it before, however.
Honestly as I personally have a CIS SC 3.0 I would say swap for a 3.2 with DME unless you enjoy beating your head against a wall trying to get CIS to work right/reliably.
Or rebuild your 3.0 (or a 3.2) with Carbs and forget the injection.
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches
PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing
Old 06-11-2013, 09:09 AM
LakeCleElum's Avatar
Can you transfer the registration to a county that does not have emission testing? Did that in my state by getting a PO Box where my cabin is.
At the same time, I transferred my voter registration and Drivers License address. That made it all legit (sort of)....Just a possible option.
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 06-11-2013, 09:15 AM
Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
I say...replace the head studs with OEM steel or Supertec, along with all the other "while you are in there" bits, and bolt her all backup with what you've got. CIS can be made to run quite reliably, although you might beat your head, as mentioned, to get it right. Once you get the CIS sorted out, it should be good to go for another 30yrs I would think the 82' engine with higer compression, with the big port heads, and the back dated exhaust would be quite nice. If you can focus your dollars at getting the CIS correctly setup, I think you will be very happy.
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 06-11-2013, 09:44 AM
47silver's Avatar
CIs is a simple system. A good vacuum and clean fuel and it will run with very little work
Old 06-11-2013, 10:08 AM
awhnry's Avatar
Move to Marion or Grundy County ie someplace upwind and very rural.
Old 06-11-2013, 11:51 AM
3.2ss
I'm turning my 1978 3.0 into a 3.2ss . Lots of options with this engine. Lots of info on this forum.
Jeff
Old 06-11-2013, 12:46 PM
Black and Blue
Kemo's Avatar
Jeff
that should be a hot setup
Kemo
Old 06-11-2013, 12:51 PM
One other option is to go to EFI with megasquirt - with your exhaust and intake runners it could be pretty fast and you could also add ignition.. you could get it pretty clean from an emission standpoint and have a lot of flexibility.
Also, are you sure you need to get an 82 emissioned?
Kinsley
1980 SC Targa - MS2, EDIS
Old 06-11-2013, 01:12 PM
AutoBahned
RWebb's Avatar
what are the actual emissions constraints?
Old 06-11-2013, 01:43 PM
Reiver
Reiver's Avatar
Fix it. Back to stock is a good place to start from...I've had great fun with stock 3.0 both 930-16 and 930-10. Very solid and stout they are.
If you need a cat let me know, I'll just about give it to you...shipping.
Old 06-11-2013, 06:34 PM
JED
ARCSinAK's Avatar
Turn her into a 3.4, Twin plug high compression JE pistons 250 HP rocket 46 PMO!!
Old 06-11-2013, 11:27 PM
ROW '78 911 Targa
timmy2's Avatar
BTDT... fix the studs and do this...
Full saga of my car is here, this EFI Bitz kit mod is around page 6 or so.
Finally, back in the game!
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 06-11-2013, 11:53 PM
Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
That's almost the same setup as my motor, fyi. I've got the smaller intake runners though.
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 06-12-2013, 01:15 AM
Thanks for all of the information. Someone asked, so here's the info on Hamilton County emissions:
1. It goes back to 1974 (!!!) - "Special" for this county.
2. They always look for a catalyst in place on cars that had them - that's a biggie with these guys.
3. Otherwise "sniffer numbers" are: CO - 1.2% or less, HC 220 ppm or less. That's for everything from 1981 until 1995 and the onset of OBD II.
I really liked some of your suggestions particularly the one about using my current heads and intakes with the aftermarket injection. Where can I find out more information on it, and do you think it would get me past emissions with a stock exhaust and gutted cat in place?
Old 06-12-2013, 04:21 AM
As for the cat, I have a complete exhaust system with cat that I purchased right after seeing what I had with the car. (The reason I didn't know ahead of time is that initially all the tires were flat and I couldn't even look under it!)
HOWEVER, the HE's I have are thick flange and they won't go onto the pre-'82 heads which have short studs. So what I need is a set of decent crossover HE's with thin flanges to get it past emissions, then I'll probably refit the HE's I have.
Old 06-12-2013, 04:29 AM
AutoBahned
RWebb's Avatar
someone put $$ into those heads, so I would not go back to stock
be certain there is no antique or historic or other case by case exemption process
if not, then Tbitz is a cheaper EFI system;
I might try to find where I could get dual free-flow (low restriction) cats - you might talk with RarelyL8 about that
aftermarket EFI can be time consuming, but the potential for lots of power AND low emissions is there
I would not want to move further out for emissions - Chattanooga is a prime spot (for Tenn.) with many amenities
Old 06-12-2013, 11:56 AM
awhnry's Avatar
Depending on the circumstances, you can register the car in Loudon County and leave it in my garage when you arent driving it. Unfortunately Chattanooga sits in a bowl with high ridges or small mountains to the east so that the prevailing winds push the various pollutants into the area with no escape. Having a large number of yankees and other types drive thru town on I-75 on a daily basis doesnt help things either. Knoxville suffers from the same situation and the locals attempted to correct the situation by lowering the speed limit on the interstate. Not sure what it does for pollution but it sure makes for a great speed trap.
It is my plan to register my '87 as classic if the locals are required by EPA to do more. How do the locals keep their old pickups on the road?
Old 06-12-2013, 12:07 PM
