Really bad Tranny mount?
Hi All,
Are these mounts on my '86 Cab really bad or should there be a separation at the top? I know they can (and will) be replaced, but is it so bad I shouldn't drive on any trips with them like this? Thanks, Franny ![]() ![]()
White '86 Carrera Cab "Shamu" |
Schleprock
They look fine in terms of the rubber integrity. No cracking or separation.
But they're missing a large washer on the top side, similar to the third picture where the big washer is under the bolt head.
Kevin L '86 Carrera "Larry" |
Senior Advisor
they do sag down but that's normal. any shifting problems?
08 Cayenne Turbo |
Huh... I wonder where that went missing to...
I want to take a couple hour drive with the car and am wondering if they have to be replaced before the trip. I don't really have the time, but I started poking around because of shifting inconsistencies. I think the tranny and engine are doing a bit of a jig back there and that is why 1-2 shifts are very hit or miss (my current theory at least). There is also a bit of lurching in 1st gear in a parking lot at low speeds on and off the throttle. Missing the big washer... How do you forget that? Thanks, Franny
Yup to the shifting problems
![]() I also meant to add that I have replaced all the shift linkage bushings and the coupler. That did help a lot, but it is still a bit inconsistent. I want to swap out the 10+ year old Swepco as well. Gotta love deferred maintenance! f
White '86 Carrera Cab "Shamu" Last edited by frannyB; 06-14-2013 at 03:39 PM.. |
Undocumented User
come now.. it's a 915 tranny, of course there's shifting problems. but I'm sure with new bushings and coupler refresh it will be back to 95% as new. unless he's it's also in need of syncros etc.
The poly inserts our hosts sells are very cheap and will stiffen things up nicely there. |
Yeah, but I would expect consistent shifting... Maybe?
It is much better when the tranny is cool, not hot. I think that is the old fluid. supposedly the 1st and 2nd was re-built about 10K ago (according to the docs). I have read that bad engine and tranny mounds make the higher torque shifts inconsistent. I don't go much above 4K in 1st and that helps. 5K would be a better match for 2nd gear though I think. It really would be nice to have a new car as a "control". I never know if what I have is normal or not. Thanks guys, Franny
Schleprock
I hope you're joking about the gear oil that's 10+ years old
Senior Advisor
under torque is where you have problems with old mounts, thats where new trans mounts shine. yes, new bushings and couplers will amaze you. change the oil
08 Cayenne Turbo |
I will change the oil this weekend. So many maintenance items to get through! I think the tranny oil in the 356 was about 20 years old when we picked it up - it was one of the first things we did.
Thanks again for all your help! Franny
