Door hinge post repair.
Too many pin holes. Replaced with a fairly decent replacement. Not a bad fit for non OEM. ![]() ![]() ![]() ![]()
Don't buy a Porsche until you can afford two. 1980 SC - sold 1983 SC - sold 2000 C4 - sold 1967 912.5 in DIY build |
Final welds and seam sealer for the front.
![]() ![]() ![]() ![]() Some fabrication to take the Carrera oil lines. And an semi successful attempt to straighten some of the dings. ![]() ![]() ![]() ![]() ![]()
Final coat of primer.
Don't buy a Porsche until you can afford two. 1980 SC - sold 1983 SC - sold 2000 C4 - sold 1967 912.5 in DIY build Last edited by Matthew Barnes; 03-13-2018 at 03:45 AM.. Reason: wrong photos |
Looks pretty good
A few last jobs before interior paint:
grind off all the rotten carpet buttons, mounting points and fix two holes in the seat pan. Not pretty but strong. ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Mask and ready for paint.
A coat of satin black for the dash (planning on not having a dashboard) Sad to cover up this piece of the car's identity, but at least it means there is something for the next caretaker to discover. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Been looking forward to these updates for a long time Matthew!
'70 911T (AKA Bottomless Pit) - Undergoing restoration '13 Audi A4 1.8T - Surprisingly fun means of getting to work |
First coat, seam sealer and a good sand.
Final coat.
![]() ![]() ![]() Looks pretty good with some of the bits I have collected. Still, a long way from bolting them in. Back to the exterior. Some work required to get my flare repair. Apply. Sand. Reapply. Sand. Rereapply Sand. ![]() ![]() ![]() ![]() And then take most of it off and get to work with a dolly and a body hammer!
Another quick repair before the stenotype went on
A bit out of sequence, but the underside got seam sealer before the undercoat.
Final stone chip.
Glad to be done with the stuff. ![]() ![]()
A bit of a tangent.
Started playing with the doors and custom door cards. In order to rectify some enthusiastic but badly executed repairs I needed to get better access to the outside door skin. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Once I had done this there was no turning back.
This was the first prototype.
A proof of concept. The final versions will be done in ALU. I was avoiding more this.... ![]() ![]() ![]() ![]() ![]() But the doors are reasonably straight now. With less filler than I thought I would need.
This slowed progress somewhat.
Lucky to get away with only 15 stitches. Beware a fresh flap disk...
Back to fibreglass.
The hood needed some work. ![]() ![]() ![]() ![]() ![]() ![]() ![]()
of ****!! get well soon!!
great build so far. much respect for THIS mega effort! Cheers!
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
And more fibreglass.
