Almost a year since I last updated the thread.
(insert suitable 'time flies' analogy) Thankfully the build has progressed, albeit not as much as I would like. Will attempt to fill in the blanks. |
http://forums.pelicanparts.com/uploa...1403521260.jpg
http://forums.pelicanparts.com/uploa...1403521325.jpg http://forums.pelicanparts.com/uploa...1403521397.jpg Sills have been patched in the past. It seems the rust was left behind! http://forums.pelicanparts.com/uploa...1403521473.jpg http://forums.pelicanparts.com/uploa...1403521504.jpg |
Into the garage finally.
http://forums.pelicanparts.com/uploa...1403523082.jpg Started stripping the suspension http://forums.pelicanparts.com/uploa...1403523125.jpg http://forums.pelicanparts.com/uploa...1403523160.jpg Roof filled with spare bits. "Better to have it and not need it, rather than need it and not have it.." http://forums.pelicanparts.com/uploa...1403523243.jpg http://forums.pelicanparts.com/uploa...1403523269.jpg |
Part of the stash we found was a rather sorry LHD 70 Targa.
We decided to donate it's remaining organs to the resto of my mate's 0001 66 S Proto and my humble lawn ornament. Floor pan (nice saving once stripped of the b@$%^%d underseal) http://forums.pelicanparts.com/uploa...1403523502.jpg http://forums.pelicanparts.com/uploa...1403523589.jpg http://forums.pelicanparts.com/uploa...1403523606.jpg http://forums.pelicanparts.com/uploa...1403523628.jpg |
Traded the tired 2.7 (Kjet) that was in the car for 2 gearboxes: a 4 speed and a 5 speed 901.
http://forums.pelicanparts.com/uploa...1403523914.jpg Engine looks tired cosmetically but complete. It turns and the MFI pump seems to be okay. Will only really know when we get it onto a jig and try and run it. 2.2E with all standard internals (as far as I know). Plan is to run it as is, hopefully won't have to open it up to get it going. May add an alu clutch plate / flywheel for a bit more zing, but otherwise standard spec would should give 155-odd horsepower. http://forums.pelicanparts.com/uploa...1403524028.jpg http://forums.pelicanparts.com/uploa...1403524064.jpg http://forums.pelicanparts.com/uploa...1403524147.jpg http://forums.pelicanparts.com/uploa...1403524200.jpg http://forums.pelicanparts.com/uploa...1403524221.jpg http://forums.pelicanparts.com/uploa...1403524265.jpg http://forums.pelicanparts.com/uploa...1403524284.jpg MFI pump is correct for a 2.2E and seems to be unmolested. http://forums.pelicanparts.com/uploa...1403524338.jpg http://forums.pelicanparts.com/uploa...1403524590.jpg |
Visited a local specialist to do some parts swapping.
The mechanical mind behind the Dutchman Cars, Tim Abbot. This is the Dutchman Racer in build. Great colour. http://forums.pelicanparts.com/uploa...1403525087.jpg http://forums.pelicanparts.com/uploa...1403525186.jpg http://forums.pelicanparts.com/uploa...1403525207.jpg |
After 9 months at the Panelbeaters (the most useless bunch of idiots in the World) I got my SC back. The wife is not impressed about the fact that her garage is filled with 2 porkers.
http://forums.pelicanparts.com/uploa...1403525570.jpg http://forums.pelicanparts.com/uploa...1403525594.jpg http://forums.pelicanparts.com/uploa...1403525780.jpg |
A few more pics of The Dutchman Racer with the interior done.
http://forums.pelicanparts.com/uploa...1403525899.jpg http://forums.pelicanparts.com/uploa...1403526010.jpg |
Finally got the car into the jig and sent it off to the sand blaster.
Couldn't face the thought of stripping the underside by hand. http://forums.pelicanparts.com/uploa...1403535549.jpg http://forums.pelicanparts.com/uploa...1403535572.jpg http://forums.pelicanparts.com/uploa...1403535587.jpg http://forums.pelicanparts.com/uploa...1403535606.jpg http://forums.pelicanparts.com/uploa...1403535623.jpg http://forums.pelicanparts.com/uploa...1403535652.jpg http://forums.pelicanparts.com/uploa...1403535688.jpg |
Lovely rough, clean metal for the epoxy primer to bond to.....and lots of nasty repairs
Door lock post to sill: http://forums.pelicanparts.com/uploa...1403535797.jpg Bottom of the door hinge post: http://forums.pelicanparts.com/uploa...1403535813.jpg http://forums.pelicanparts.com/uploa...1403535865.jpg Inside the sill cavity. Inner sills look pretty solid but they'll come out when I'm in there. http://forums.pelicanparts.com/uploa...1403535901.jpg http://forums.pelicanparts.com/uploa...1403535966.jpg Below the torsion bar tube: http://forums.pelicanparts.com/uploa...1403535997.jpg Suspension pan: http://forums.pelicanparts.com/uploa...1403536027.jpg http://forums.pelicanparts.com/uploa...1403536060.jpg http://forums.pelicanparts.com/uploa...1403536083.jpg Lots of rot to cut out but to be honest I thought it would be worse, so not too stressed. |
Went for a spin in one of these.
What a car. Docile and gentle....until you put your foot down. That motor is utterly addictive. http://forums.pelicanparts.com/uploa...1403595732.jpg http://forums.pelicanparts.com/uploa...1403595753.jpg |
Started cutting away the rotten suspension pan and fuel tank carrier.
I spent a few hours drilling out the spot weld on the fuel tank support and then decided to cut out the whole thing and grind away what was left of the seams. http://forums.pelicanparts.com/uploa...1403597511.jpg http://forums.pelicanparts.com/uploa...1403597192.jpg http://forums.pelicanparts.com/uploa...1403597211.jpg http://forums.pelicanparts.com/uploa...1403597230.jpg http://forums.pelicanparts.com/uploa...1403597251.jpg |
I hope I can save the front panel ($600 odd from RD) and patch along the sides and along the bottom. Here is my attempt at creating a patch template.
http://forums.pelicanparts.com/uploa...1403598096.jpg http://forums.pelicanparts.com/uploa...1403598111.jpg http://forums.pelicanparts.com/uploa...1403598125.jpg A sort of rally patch.... |
Wow, there is a lot of work there! I'm 50% jealous and 50% relieved that it is not me, haha!
The patch idea looks good. While you are at it, you can also work in a bit of a recess for an RSR style oil cooler... mmmmm... |
Kinda what I'm getting at....
http://forums.pelicanparts.com/porsche-911-technical-forum/506207-elephant-oil-cooler-duct-install.html I know the vision a 911R of sorts, but this could still be a nice touch. |
What does that 2.2 E engine have a green shroud? The green shroud is a midyear 911S item. It should be black on a 2.2E engine.
Don't get me wrong, the green shroud has better air flow but would cause me to look a bit deeper into what this engine actually is. |
Thanks Bear911.
To be honest doesn't feel like I've done that much when I see the car in the garage every day. New steel welded in and everything in primer will be a major milestone. Can't wait for it to be all in primer. Sanding primer gives a sense of progress.....strange considering that after years on shiny boats I can't bare bloody sanding! Chin cooler mod is interesting. Would solve my missing metal problem. But it necessitates an rs front bumper? I have a 's' front bumper. Will run an oil cooler in the wing. I think the rs/r front bumper with oil cooler works on the hips of an rs/rsr. Last week's plan was to keep the skinny hips of this one......but do have a set of original steel carrera flares. |
Green is correct for an early E. T was yellow, E was green, S was red. 73.5 was black over yellow gell coat.
It's a 2.2E.
As Flieger correctly details. At numbers / part numbers are correct. The internals may have been changed, the mfi pump recam'd, but I doubt it. 155/160hp in a light car should be more than enough for me. |
Started spraying suspension parts. 2K primer, then satin black.
http://forums.pelicanparts.com/uploa...1403768067.jpg Good parts to practise my spraying http://forums.pelicanparts.com/uploa...1403768107.jpg http://forums.pelicanparts.com/uploa...1403768294.jpg http://forums.pelicanparts.com/uploa...1403768320.jpg SWB trailing arms....rare little buggers. http://forums.pelicanparts.com/uploa...1403768340.jpg http://forums.pelicanparts.com/uploa...1403768381.jpg http://forums.pelicanparts.com/uploa...1403768400.jpg |
Started on the body.
Used a sponge roller to get the first coat on, on the outside. Sandblasted steel gives a great surface for the paint to bond to. http://forums.pelicanparts.com/uploa...1403777600.jpg Then broke out the spray gun to do the interior and underside. http://forums.pelicanparts.com/uploa...1403777667.jpg http://forums.pelicanparts.com/uploa...1403777703.jpg http://forums.pelicanparts.com/uploa...1403777722.jpg http://forums.pelicanparts.com/uploa...1403777740.jpg http://forums.pelicanparts.com/uploa...1403777766.jpg Indicator housings were remarkably intact. http://forums.pelicanparts.com/uploa...1403777789.jpg |
Then some sanding and a second coat of primer.
Changed colour to help with cutting through. Lovely stuff to sand. 180 then 400 wet and dry. http://forums.pelicanparts.com/uploa...1403777931.jpg http://forums.pelicanparts.com/uploa...1403778019.jpg http://forums.pelicanparts.com/uploa...1403778051.jpg And more sanding....and more sanding. |
180
400. 800. 1200. Repeat. Getting ahead of myself but the roof and quarters come up beautifully when you spend the time with the sand paper. But lots of rust to sort before we get close to getting the primer smooth. http://forums.pelicanparts.com/uploa...1403796054.jpg |
The bottom of the car looks a bit like a sieve in places.
Some places will need to be cut out and patched, but the repairs don't give me access to places that will no doubt have surface rust: suspension tube, bottom of the rear wheel house below the torsion tube, transmission tunnel, the box section in the engine bay, behind the heater tubes and in the cavities behind the lower suspension pan. So my plan involved a petrol sprayer and water-based rust converter. Dilute the rust converter 2 to 1 and use the petrol sprayer to blast the stuff into every cavity until it drips out the various rust holes. Then cover with a rust converter primer (similar to red oxide but without the etch aspect) http://forums.pelicanparts.com/uploa...1403796896.jpg http://forums.pelicanparts.com/uploa...1403796912.jpg Bottoms of the doors are rotten (to be expected) but the rest is solid. http://forums.pelicanparts.com/uploa...1403796965.jpg http://forums.pelicanparts.com/uploa...1403797026.jpg http://forums.pelicanparts.com/uploa...1403797112.jpg http://forums.pelicanparts.com/uploa...1403797203.jpg |
New steel is a little pricy with a 10 to 1 exchange rate, and transcontinental shipping!
But now have all I need...or rather the minimum. Have avoided ordering a front slam panel and the floorboard clip helps....two very expensive parts (considering no-one does a rhd replacement floorboard). http://forums.pelicanparts.com/uploa...1403797614.jpg The floorpan involved the now familiar hand stripping with torch, scraper and then 3M wheel. A nasty job. But considering the saving...... http://forums.pelicanparts.com/uploa...1403797473.jpg The parts have been a mix of RD and Sportwagon Eckhart . SE is a bit cheaper on account of there being a few direct flights a week from Germany to SA. Both have been great to deal with. You got mail. http://forums.pelicanparts.com/uploa...1403797717.jpg 964 outer rockers very kindly 'loaned' to me. Indents will have to be flattened. http://forums.pelicanparts.com/uploa...1403797758.jpg http://forums.pelicanparts.com/uploa...1403797818.jpg http://forums.pelicanparts.com/uploa...1403797849.jpg These replacement lower hinge post patches are great. Decent gauge and a nice fit. From Sportwagon Eckhart. http://forums.pelicanparts.com/uploa...1403797881.jpg My only criticism are RD's rear window corners. They have no gutter lip. Will have to fashion some. A tricky little piece of work despite paying 120 $ for 2 parts. http://forums.pelicanparts.com/uploa...1403798028.jpg http://forums.pelicanparts.com/uploa...1403798060.jpg Interesting idea for the rear parcel shelf that needs the corners done.....like they all do. Smuggler's box pressing is the same as the parcel shelf on the swb cars. So I reckon I can sacrifice this spare cover to make two patches. http://forums.pelicanparts.com/uploa...1403798143.jpg Now all I need to do is get all these bits welded in! Simple.....when you know how. |
Shiny new metal, nice! How do you plan on flattening the indentations on the rocker panels?
Time to start with the welding.
After getting numerous quotes and trying to puzzle different ways of paying for the body to get sorted, I decided to do the metal work myself. Short of a broken shackle on a wind pump, I've never welded anything before. I've digested a lot of theory from this forum and from the tube. We'll see how reality compares. I've borrowed a little machine from a mate. Clarke 90 Amp. 25/75 gas and .8mm wire. Lots of practise on different gauge scrap to get the wire speed sorted......and some muscle memory. http://forums.pelicanparts.com/uploa...1406529789.jpg http://forums.pelicanparts.com/uploa...1406529811.jpg http://forums.pelicanparts.com/uploa...1406529840.jpg |
The first real project is to patch two rust spots at the front and rear of the longitudinal.
http://forums.pelicanparts.com/uploa...1406530015.jpg http://forums.pelicanparts.com/uploa...1406530048.jpg http://forums.pelicanparts.com/uploa...1406530071.jpg Steel behind the lower door post corner is not great. Looks worse on camera than it is. If it weren't in such a tricky spot I would cut it out. http://forums.pelicanparts.com/uploa...1406530145.jpg http://forums.pelicanparts.com/uploa...1406530241.jpg Rear Patch http://forums.pelicanparts.com/uploa...1406530093.jpg And a coat of paint over the rust converter before it all gets covered up. http://forums.pelicanparts.com/uploa...1406530367.jpg Also drilled a hole at the top of the door hinge post to allow me to spray rust converter in the top...and wax when the time comes. Plan is to drill quite a few of these through the chassis: rear box sections, wheel house corners etc. http://forums.pelicanparts.com/uploa...1406530479.jpg |
Next step the inner sill.
Clean off the factory black, drill, fit. http://forums.pelicanparts.com/uploa...1406530703.jpg http://forums.pelicanparts.com/uploa...1406530732.jpg http://forums.pelicanparts.com/uploa...1406530771.jpg http://forums.pelicanparts.com/uploa...1406530802.jpg There is a Porsche in there somewhere..... http://forums.pelicanparts.com/uploa...1406530831.jpg Had a few goes to make sure the welds were penetrating. Drilling out dodgy welds are school fees I guess. http://forums.pelicanparts.com/uploa...1406530879.jpg http://forums.pelicanparts.com/uploa...1406530992.jpg http://forums.pelicanparts.com/uploa...1406531036.jpg Not going to win any prizes, but it's solid and straight. |
Jack tube support plate. I'm sure there are better / smarter ways to do this but this seemed to make the most sense to me, with my limited skills.
Step 1. http://forums.pelicanparts.com/uploa...1406531189.jpg Step 2. A mate gave me a great tip: I-Beam scraps as an anvil. A piece of railway track is ever better, but haven't managed to find a piece yet. http://forums.pelicanparts.com/uploa...1406531281.jpg Step 3. http://forums.pelicanparts.com/uploa...1406531411.jpg Step 4. I need to get a mini cutting disk for the air grinder. A mini grinder with a 4 inch disk makes cutting accurately quite tricky. http://forums.pelicanparts.com/uploa...1406531452.jpg Step 5. http://forums.pelicanparts.com/uploa...1406531517.jpg Step 6. http://forums.pelicanparts.com/uploa...1406531538.jpg Step 7. Backing plate. I welded a piece of round bar scrap to the I-Beam to make a buck / anvil. Radius is perfect for the bottom curve of the body. http://forums.pelicanparts.com/uploa...1406531568.jpg Step 8. http://forums.pelicanparts.com/uploa...1406531727.jpg |
Step 9.
http://forums.pelicanparts.com/uploa...1406531754.jpg Step 10. http://forums.pelicanparts.com/uploa...1406531846.jpg Step 11. http://forums.pelicanparts.com/uploa...1406531866.jpg Step 12. Drilled and ready for welding. http://forums.pelicanparts.com/uploa...1406531907.jpg Quite proud of this. |
Strip off the factory black and etch prime.
http://forums.pelicanparts.com/uploa...1406532049.jpg http://forums.pelicanparts.com/uploa...1406532070.jpg That was about 12 hours of work. Next steps: - lower door hinge post - rust patch behind kidney - kidney - outer sill - door lock post patch into outer sill - lower flare cut welded back on.... And then the same on the other side. And the front, and the floor pan, and the parcel shelf, and the rear window corners. The trick is to focus on what you have done, and not what is still to be done. A lot like life I guess. |
Nice progress! I really like your solution to a jacking tube, and the welding looks just fine!
Nice work.
Next step: closing up the indents on the 964 sills.
Good practice for welding and grinding. These things are filled with holes. http://forums.pelicanparts.com/uploa...1407741383.jpg http://forums.pelicanparts.com/uploa...1407741413.jpg A makeshift anvil. Round tube welded to a piece of I-Beam scrap. http://forums.pelicanparts.com/uploa...1407741453.jpg http://forums.pelicanparts.com/uploa...1407741479.jpg Welded up and ground down. Not the prettiest but a thin skim of filler will finish it off. http://forums.pelicanparts.com/uploa...1407741505.jpg http://forums.pelicanparts.com/uploa...1407741590.jpg Stronghand Tools. Good quality and a good price...even when imported with a silly exchange rate. Can never have too many clamps. http://forums.pelicanparts.com/uploa...1407741640.jpg |
Lower door hinge post patch.
Restoration Design. Pretty good fit. http://forums.pelicanparts.com/uploa...1407741797.jpg http://forums.pelicanparts.com/uploa...1407741818.jpg |
And the dreaded shut lines.
Doors from a 71 targa. Sills from the 90s. Shell from 67. Have been terrified of this step - combination of how much filler and fiberglass there was in the old patchwork of rusted, layered steel that were pretending to be outer sills, and my lack of skill / experience working steel. I hoped that somehow, by some miracle, I would be able to fit everything back together with the minimum of hammering, shaping and four-letter words. http://forums.pelicanparts.com/uploa...1407742020.jpg http://forums.pelicanparts.com/uploa...1407742037.jpg http://forums.pelicanparts.com/uploa...1407742060.jpg http://forums.pelicanparts.com/uploa...1407742087.jpg All credit to Porsche. Their bits really are made properly. Usually a fair amount of lead, but mine was fairly unleaded. Unlike the FBG front wings. Has anyone, ever, in the history of car construction received FBG panels that fit? I doubt it. But at least they are FBG so working them will be relatively painless. http://forums.pelicanparts.com/uploa...1407742208.jpg http://forums.pelicanparts.com/uploa...1407742230.jpg Next step: patching the lower door lock post....... |
| All times are GMT -8. The time now is 11:37 PM. |
