Recreational User
porschenut's Avatar
What is this thing doing under my sound deadening?
I took out the carpet in my new targa, and found this metal tag entombed in the sound deadening material applied to the floor pan just in front of the driver's seat. What is this? It has numbers on it, and some thin wire that wasn't attached to anything. It doesn't seem like it belongs there. Was it just some debris laying on the pan when they coated it? This is an '86 targa.
Old 05-19-2013, 03:52 PM
Almost Banned Once
sc_rufctr's Avatar
That's an ID tag for the body from the factory. It shouldn't be there because these are discarded after the body is built.
The factory worker who was responsible for removing these was having a bad day???
- Peter
Old 05-19-2013, 04:10 PM
steely's Avatar
I actually have one of those too, also in front of the seat.
It says something in German like: nicht strafbewehrt entfernen
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 05-19-2013, 05:11 PM
m110's Avatar
I have one too. There is a thread about a guy who found a beer bottlecap there as well.
1988 Carrera Coupe
Old 05-19-2013, 05:19 PM
Recreational User
porschenut's Avatar
You mean it's like a mattress tag? I better glue it back in place.
Old 05-19-2013, 05:30 PM
non-whiner
mreid's Avatar
German dog tag. It's good luck!
"Too much is just enough."
Old 05-19-2013, 06:06 PM
I found a half used German lipstick, apparently the worker had a...visitor...while prepping the undercoating and she forgot to clean up after herself
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 05-20-2013, 08:25 AM
AutoBahned
RWebb's Avatar
maybe a tranny put in the tranny
Old 05-20-2013, 10:55 AM
Functionista
manbridge 74's Avatar
Hilarious!
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 05-20-2013, 11:35 AM
So put me on a highway
More Info
What does this ID plate tell me?
1985 911 Euro Cab.
Old 05-20-2013, 05:32 PM
Recreational User
porschenut's Avatar
Wow, thanks for the link jlcinga. I was ready to ask if the line workers were drunk when they coated the body pans with debris underneath, but it appears to be intentional. Couldn't they have just stamped the pan like the rest of the body parts instead of burying a loose tag under the floor material?
I just went and checked my '88 and it has a tag there too. It's still buried so I didn't disturb the coating, but the outline of the tag can be seen clearly.
Old 05-20-2013, 07:34 PM
djpateman's Avatar
Yes, the # should also be stamped in the frame. I am not sure why they leave the loose tag in many of the cars. Makes for interesting research.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 05-21-2013, 07:09 PM
Found the same in my '89 C4 last sunday. Mine was rusting away, so I discarded it.
Old 05-21-2013, 08:34 PM
It's the body number. It can also be found stamped behind the passenger kneepad and written on the doors in grease pencil behind the door panels.
1 (body) 1 (targa) 6 (1986) 5476 (sequential production number)
It is basically the serial number for the body just like an engine or transmission number. legally in Germany the body is just another replaceable part like an engine or transmission.
Old 05-21-2013, 08:44 PM
group911@aol.co's Avatar
Mine was still tied to the front latch panel with the wire shown and painted along with the car.
86 Model
Thanks,
Bob
group911@aol.com
Old 05-21-2013, 08:51 PM
djpateman's Avatar
Bob, could you post a photo of it wired to the latch panel. I wonder how many other places it can be found. I suspect that the latch panel might be the original location, then most are removed for painting, possibly winding up in the left footwell.
Addicted since 1975
Old 05-22-2013, 12:09 PM
Recreational User
porschenut's Avatar
Thanks for the decoding. My door panels are currently off but I don't see any numbers on the door sheet metal. Were they possibly painted over?
Old 05-22-2013, 12:25 PM
What number for a cab?
Originally Posted by djpateman View Post
It is the chassis # tag. 1155185 decodes as:
1 = production body (0) is replacement
1 = targa body (0) is coupe
5 = year
5185 = sequence #
1985 911 Euro Cab.
Old 05-23-2013, 04:37 PM
Here it is hanging where I found it. Pretty sure this is original location as you can see the area behind it that the paint missed.
Thanks,
Bob
group911@aol.com
Old 05-24-2013, 08:37 PM
djpateman's Avatar
From your previous thread the production # starts 11, so I have to guess that the 1 is for both Targa and Cab. A bit odd I know, but they made no distinction between coupe, sunroof coupe, RS body. RHD/LHD, or 911/912. There was a distinction between Porsche and Karmann bodies though; 0 & 2 respectively.
Thanks for the photos Bob, that really helps.
If anyone else can add information to this thread, please do so. I need to continue this research. PM's are always welcome.
Addicted since 1975
Old 05-27-2013, 07:12 AM
