Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
Turn key to "On" - Have power and fuel pump. Turn more to start: Lose all electrical
No idea what's going on here.
As I said...if I turn the key to the on position, I get dash lights and fuel pump. If I continue to turn, all electrical shuts down.
I've been messing with my Pertronix today, including splicing the red wire inside the distributor. I've also un-taped all of my wiring in the engine compartment, so the possibility of something becoming unplugged or pulling out a bit exists. I have checked and moved every wire in the engine compartment, every fuse, my battery....I'm stumped.
I'm turning the key and getting nothing now. NO idea.
Help?
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 05-22-2013, 04:30 PM
This happened to a friends car. Somehow the starter burned up, replaced starter and car fired right up. Not sure that's your issue but it was his.
Old 05-22-2013, 05:15 PM
Chain fence eating turbo
Fun! You get to trace the circuit all the way to the starter.
Old 05-22-2013, 05:25 PM
Air Medal or two
afterburn 549's Avatar
KISS
Clean all terminals, grounds B4 getting to far out !
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 05-22-2013, 05:35 PM
Rennch on YouTube
rennch's Avatar
it's really strange. I can turn the key on...and nothing. Then fiddle around with wires in the engine compartment, and I'll get power. At this point, I've got the motor in a partial drop, I've unplugged and plugged every wire, and I can't seem to identify the culprit. It's maddening.
Michael O'Neal -
Old 05-22-2013, 05:42 PM
ROW '78 911 Targa
timmy2's Avatar
Has your partial drop strained the ground cable to the body at the transmission?
Maybe it has "opened " the connection or the cable at some point. Or another connector or cable in the engine bay?
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 05-22-2013, 06:49 PM
Air Medal or two
whats your voltage drop to starter ?
Whats your "cranking " voltage?
Old 05-22-2013, 07:06 PM
ROW '78 911 Targa
timmy2's Avatar
Looked at your build thread, very nice. How did you wire in the 3.0 engine harness to the '69 wiring?
Did you build an adapter for the 14 pin connector or split it out to the existing system?
Your red and yellow wires in the 14 pin connector (if it still exists) are power and start signal.
Dennis
Old 05-22-2013, 07:15 PM
RETIRED
Joe Bob's Avatar
Check terminals connections. Classic corrosion or loose terminal symptoms.
Meter the battery. likely voltage as well.
2012 ML350 3.0 Turbo Diesel
Old 05-22-2013, 07:41 PM
Rennch on YouTube
rennch's Avatar
I'm so frustrated I want to take a torch to it. I don't have a working multimeter and I truly don't know how to use it.
Old 05-22-2013, 08:11 PM
Air Medal or two
takes just a plain old volt meter to measure drop..pretty simple sorry for you problems
Call it a night, tomorrow will be brand new
Old 05-22-2013, 08:13 PM
RETIRED
Joe Bob's Avatar
Coming down this weekend to SD....call me. I can help....send me a PM with your number.
Old 05-22-2013, 08:17 PM
If you're a risk taker you can see if it'll pop start. My friends with that problem would pop start.
Old 05-22-2013, 08:21 PM
Justin@Athens's Avatar
Send a message via AIM to Justin@Athens
This may be a dumb idea, but have you considered the ignition switch itself?
1990 964 C4 Coupe & 1991 964 C2 Coupe (current)
1989 911 Targa (sold)
1996 993 Cab. (sold)
1999 x2 Boxster (sold)
2006 Cayman S (my daily)
Old 05-22-2013, 08:23 PM
T77911S's Avatar
sounds like a bad battery or bad battery connections. clean both battery connections and clean the grounds from the battery to the body. do the same with the ground strap on the tranny.
have the battery tested.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 05-23-2013, 04:30 AM
Rennch on YouTube
rennch's Avatar
It can't be...it switches intermittently between full power and zero power. Joe Bob had a good suggestion that it might be a broken ground somewhere. I'm going to install my new ignitor and keep troubleshooting from there.
The battery is brand new, btw.
Michael O'Neal -
Old 05-23-2013, 09:41 AM
T77911S's Avatar
bad connection. clean them, pos and neg.
RACE CAR:: sold
Old 05-23-2013, 09:46 AM
Rennch on YouTube
rennch's Avatar
It's not a bad connection at the battery. But I'm guessing it's a bad connection somewhere in the engine compartment, exacerbated by my untaping the wiring loom. I've just gotta find the bugger.
Michael O'Neal -
Old 05-23-2013, 10:42 AM
AutoBahned
RWebb's Avatar
$10 and 10 minutes
Old 05-23-2013, 12:40 PM
Eng-o-neer
Tremelune's Avatar
This is where you start (though a simple test lamp will probably work in your case).
You mainly just need to know where 12v should be when trying to start the car, and where it should be coming from. Somewhere in there is a break in the chain...The tricky bit is knowing where to test.
Old 05-23-2013, 01:41 PM
